MaxToLux - 3ds Max Integration for LuxCoreRender
Nice, you get it now. Of course, for better control later you can add "Lux scale map" either.
By the way, can you confirm, the material editor does not crash anymore or the problem still persist?
Latest build Download link👇👇
https://forums.luxcorerender.org/viewto ... 378#p28378
yes it keeps crashing max when I open the compact material editor, but it doesn't happen with all the scenes and I know the workaround.
Do you have a special material on the scene or for example an old version of null material?
It should not crash at all.
Can you send me a scene so i see what i missed?
And remember, do not save scenes with filesaver enabled, i will fix that very soon.
I can pack the scene, it's the luxball scene. There is no null material.
The issue happens with compact material editor. You may try yourself first: open a scene, instead of slate open the compact mat editor, it might crash max.
Btw, I ask you to send me the sponza scene, I still didn't receive. I need to understand how you did manage such soft bump. I've been not able to replicate it
Check your personal messages.patro wrote: ↑Sat Feb 20, 2021 11:27 pmI can pack the scene, it's the luxball scene. There is no null material.
I cant see the problem, it's not crashing for me at all. a simple scene, complex scene, empty scene, I tried all but nothing happened.
MaxToLux v0.8.2705-beta
Plugin Download link available for 3dsmax 2019-2020-2021 in a single installer package https://github.com/LuxCoreRender/MaxToLux/releases
Fixed Bugs
Fix the issue with non-exist bitmaps.
Fix the issue with corrupted bitmaps.
Fix the issue with not supporting file format.
Fix the issue with unreachable network files.
Fix the issue with objects with no mesh.
Fix the issue with the unnormal mesh imported from other software.
Fix the issue with the objects with missing vertexes.
Fix the issue with mesh with no face or less than 3 connected vertexes.
Special thanks to "patro" for reporting the issue and providing the scenes.
Knowing issues
Lux Cameras Missing
The perspective camera can be rendered in the wrong way sometimes.
If the fileserver option is enabled when saving the project 3dsmax will crash next time trying to open the project.
Fixed Bugs
Knowing issues
Lux Cameras Missing
@TAO I tested it
compact mat editors scene now opens without problems
btw, the sample slots seams to render faster also, meant are all slots including those which had all textures linked properly.
Wow, amazing fast. thank you for the effort.
hehe just for fun.. an old tutorial made by splatterfish their glowing logo.
very nice. In the old-time, this was a huge improvement for renderers. As i can remember splatterfish was great on light and render.
If i remember correctly Brazil renderer was the name of renderer they develop.
