Denoiser Integration
Dez!
Re: Denoiser Integration
Post by Dez! » Fri May 11, 2018 2:58 am
In anticipation of noise reduction I stopped all 3D projects. I switched to web design. In my scenes there is a lot of work for noise reduction
Elementary OS Loki | Dell Inspiron 7000 | Wacom
Post by B.Y.O.B. » Tue May 15, 2018 8:32 pm
The firefly removal of the denoiser can work pretty well, but only until too many samples have picked up the same "firefly" (which is technically no longer a firefly in this case, just an unconverged caustic).
edit: However, it seems to kill the glossy reflections. Strange.
no clamping, about 400 samples
Dez!
Post by Dez! » Thu May 31, 2018 9:47 am
Can a denoiser handle the channels of light groups?
Post by B.Y.O.B. » Thu May 31, 2018 10:25 am
Yes, but it would need to be run on each lightgroup imagepipeline separately, so it would take a lot more time than if we only denoise the "main imagepipeline".
Dez!
Post by Dez! » Fri Jun 01, 2018 12:01 pm
OK. This is really needed option. Without it, the compositing is not possible.
I propose to make such a check
I'm starting a series of 200 renders of LED strips. With noise reduction of all channels, I need to perform 50 renderings, and a bit of compositing. Without noise reduction of all channels, I need to perform all 200 renderings.
Post by B.Y.O.B. » Fri Jun 01, 2018 2:28 pm
andreymd87
Post by andreymd87 » Mon Jun 04, 2018 7:11 pm
Dade wrote:
Thu May 10, 2018 9:17 am
Did I ever said how damn well this thing works ? :lol:
A 10 mins rendering, it makes animations possible.
wow!! what are your denoiser settings?
Post by Dade » Mon Jun 04, 2018 9:31 pm
Just the default settings.
andreymd87
Post by andreymd87 » Mon Jun 04, 2018 10:57 pm
strange. i used same default settings but here are some artifacts :(
Post by Dade » Tue Jun 05, 2018 9:55 am
strange. i used same default settings but here are some artifacts :( untitled.png
Try to increase the "Histogram distance threshold" parameter, the result should be smoother.
