I have exposed this new setting in the Blender addon.
It's the "orientation" setting in the imagemap node:
Normal Map DirectX to OpenGL
Re: Normal Map DirectX to OpenGL
Wow, this is great! Thank you so much! I'm really impressed how quickly you guys incorporated this.
By the way, is this new change already available?
Not in an official release, but you can use a daily build: viewtopic.php?f=9&t=736#p9704
Sorry for not understanding, but could I have an explanation/example of when to use this new feature.
Thanks
Thanks
When you download a normal map and it says in the description that it's a DirectX normal map, then you have to use DirectX orientation in LuxCore.
For examples see https://dubcats-secret-little-hideout.f ... Normal_Map
B.Y.O.B
Thank you for the explanation and link.
+1, thanks B.Y.O.B
