Installation on 2.79b problem
chaba
Post by chaba »
Hi Guys,
I'm trying to install the Luxcore on blender 2.79b. I followed the instructions on this page (viewtopic.php?f=9&t=736&p=9704#p9704), but with no luck - I have daily build of blender and daily build of Luxcore overwritten over the master. Still no luck. The error I get is attached. It does get activated in official blender 2.79, but I cant seem to make it work in daily build. Maybe I'm doing something wrong? Heres the steps I take: 1. download the version from Downloads page 2. Install it. 3. Download a daily build of Luscore from this address (https://github.com/LuxCoreRender/LuxCor ... tag/latest), 4. Overwrite the files daily built to files in AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\bin folder.
After that I get the same message which is attached. And I have all the microsoft c++ files installed. Thank you in advance.
Re: Installation on 2.79b problem
It is simple and safer to install the lastest Blendluxcore here (Alpha 2.2) : https://github.com/LuxCoreRender/BlendL ... v2.2alpha0
Just make a simple install from file and close / relaunch blender after that.be sure to remove all previous unseccessfull attemp.
acasta69
Post by acasta69 »
Also, LuxCoreRender will not work with Blender daily builds because of the different embedded python version.
You need to use the official Blender 2.79b release.
chaba
Post by chaba »
Did it, but still get this error :(
chaba
Post by chaba »
I get it. Thanks guys.
acasta69 wrote: Mon Feb 25, 2019 9:59 pm Also, LuxCoreRender will not work with Blender daily builds because of the different embedded python version.
acasta69
Post by acasta69 »
Chaba, I have posted a link to a Python 3.7 enabled version here:
viewtopic.php?f=9&t=937&start=20#p10572
It should work with the Blender 2.79b daily build.
By the way, I forgot to say that what I wrote above applies only to Windows.
