Which binary to link with FreeCad to render?
ChintusTheGreat
Post by ChintusTheGreat » Thu Feb 07, 2019 7:08 am
After I installed the precompiled LuxCoreRender binaries, I found 4 binaries: luxcoreui, luxcoreconsole, luxcoredemo, luxcorescenedemo. But when I went to FreeCad, it asked for Luxrender binary. When I pointed it to luxcoreui, I couldn't save my renders in a .png format. Which binary do I link it to and how do I save my render as an image?
Re: Which binary to link with FreeCad to render?
Post by Sharlybg » Thu Feb 07, 2019 10:32 am
There is no addon to work with Freecad currently. you must import your Model to blender and work with Blendluxcore addon.
acasta69
Post by acasta69 » Thu Feb 07, 2019 1:17 pm
I gave it a try and it seems that LuxCoreUI crashes for some reason when selecting "Save Outputs" command after it was started from within FreeCAD.
As a workaround, you could export the raytracing project and then separately run LuxCoreUI to render it. In that case "Save Outputs" works fine.
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
ChintusTheGreat
Post by ChintusTheGreat » Thu Feb 07, 2019 1:27 pm
Thanks! Now it works nicely. :D
Post by Sharlybg » Thu Feb 07, 2019 1:34 pm
Sorry misreading again :arrow:
acasta69
Post by acasta69 » Thu Feb 07, 2019 3:51 pm
Well, the FreeCAD exporter is indeed very old, it was built for Luxrender and the lxs format, and using it with Luxcore is probably far from ideal.
I am not sure if every Luxcore option is available with that format, but it is always possible to export everything in Luxcore format from LuxCoreUI, from menu Rendering --> Export.
Post by B.Y.O.B. » Thu Feb 07, 2019 4:10 pm
No, definitely nothing of the new stuff, and only a subset of the features in LuxRender 1.6.
