Crash with small spread angles
Re: Crash with small spread angles
I reworked the triangle light source code to have consistent emitted power across various theta values.
Dade wrote: Tue Feb 13, 2018 5:14 pm I reworked the triangle light source code to have consistent emitted power across various theta values.
thanks you this is a good steps on predictability.
lighting_freak
Post by lighting_freak »
Thank you for your quick response and your hard work.
Do we have a topic in the new forum that is related to function requests? No bugs, no crashes but less priority questions?
BR
OS - Windows 7 X64
CPU - Intel CORE i7
You can post feature requests in the same places as bug reports: viewtopic.php?f=4&t=2
But it's not a problem if you post in the "wrong" forum, we are not that strict and stuff can be moved ;)
