I already search this forum and the internet but i couldn't get an answer/ solution to my problem.
I am not able to save and resume a scene with the standalone version of luxcorerender-v2.1-win64-opencl.
I can export my scene with blender and start rendering with the standalone renderer without any problem (opencl + path). Since I do not have a powerful GPU (GTX 750ti) my renderings take a lot of time, and I would like to do them whenever im off my computer. However I am not able to save and resume rendering, no matter what I try.
I can save or export the render from the GUI menu or do it via render.cfg and a periodic save. Both of the methods even produce rsm-Files, but whenever I try to resume rendering from a rsm-File the rendering process again starts at 0 samples.
Is this a bug of the current release or do I understand sth. terribly wrong?
Thanks for your support.
Peter
resume render not working
Re: resume render not working
I should have fixed the problem, you can use the LuxCoreUI included in automatic builds (viewtopic.php?f=9&t=736) and it should work fine. The build should be ready in a couple of hours.
Thank you for your reply and your work.
But when I use the build from this link (https://github.com/LuxCoreRender/LuxCor ... tag/latest) which is from January 16th, resume still doesn't work for me, maybe there is some problem with the automatic build pipeline since the last build is already almost one week old, and therefor your resume fix is maybe not part of the current build to download.
yours Peter
yours Peter
