Can it be the filesaver engine blender blend texture transformation is wrong?
I can't read 4x4 matrix, is it correct?
LuxCore render looks wrong / different.
Blender
Translate X0 Y1.19 Z0
Rotate X90 Y0 Z0
Scale uniform 17.05
Filesaver
17.0460033 0 0 0 0 1.2869375e-06 17.0460033 0 0 -17.0460033 1.2869375e-06 0 0 1.19400001 0 1
Filesaver blender blend texture transformation
Re: Filesaver blender blend texture transformation
Are you using v2.0 or the latest v2.1beta?
There is a bug when using local transformations in v2.0 which is fixed in v2.1.
I have 2.1 beta 2, will update.
No beta2 should include that fix.
Can you upload a scene that shows the problem?
I can reproduce it.
- laser_milkwater_byob.blend
- .blend file
- (336.98 KiB) Downloaded 140 times
- laser_milkwater_byob_LuxCore.zip
- .cfg/.scn
- (17.28 KiB) Downloaded 132 times
Better sample
In LuxCore from filesaver
Issue is solved for me.
Don't know how, but the global scale was easy to tune to the looks of object scale, this i was not able to do yesterday.
Yes, there's definitely a bug, but I'm not sure if it's in the addon or in the filesaver engine.
