I have a problem to install 2.1alpha4
I can not understand what to do.
Re: I have a problem to install 2.1alpha4
Have you installed the libraries listed at the end of the message viewtopic.php?f=9&t=630 ?
NOTE: Thanks to Acasta69 work, this release for Windows is compiled with VisualStudio 2017. You may need to install the VS2017 runtime libraries: https://support.microsoft.com/en-us/hel ... -downloads
NOTE: due to a bug (https://github.com/embree/embree/issues/195) in Embree v3.2.0, you need to install
also the Intel C++ redistributable (https://software.intel.com/sites/defaul ... .3.210.zip) on Windows
Yes.
I installed these packages.
Are you using the OpenCL version ? Is LuxMark working ?
Are you using Blender 2.79b or a different version?
I'm using version Blender 2.79b from blender.org
Ok, you will have to investigate what DLL you are missing. Download the stand alone version from https://github.com/LuxCoreRender/LuxCor ... opencl.zip
Unpack the .zip and run the luxcoreui.exe, you should get an error (post the message here, please).
You can than use a tool named Dependecy Walker to check what DLL you are missing, the procedure is described here: viewtopic.php?f=4&t=640&p=6412&hilit=de ... lker#p6407
When I launch LuxCore UI there is no error.
after checking "luxcoreui" with dependencywalker
This mean the problem is python related. Are you sure to use the official Blender 2.79b (Python v3.5) and not a daily build or v2.80 (Python v3.6) ?
