thanks to the new blender I was able to start my own test period now. I'm using the latest alpha2.
First I've tried a simple scene on my own and later on I've tried to run one of the scenes from "works in progress" area.
Result is the same. I'm receiving this warning:
Also the renderings appear like clay rendering without any material information.
For HDRI light sources I'm receiving the same warnings.
What does that mean to me?
Thanks.
BR
							Warning messages
				lighting_freak
Warning messages
OS - Windows 7 X64
CPU - Intel CORE i7
						CPU - Intel CORE i7
Re: Warning messages
Weird. It looks like some of the source files in your addon installation are older than others (changed function names).
Which .zip exactly did you download?
I'll check if something with the packaging went wrong.
				lighting_freak
those files I've used. Downloaded yesterday and downloaded one more variant today. Another thing. I cant remove the current luxcore add-in. Propapbly it's the strange blender/lux combination that has grown the last days.
I'll try a complete uninstall and re-setup. Thanks for your hint with mixing up things.
BR
BR
OS - Windows 7 X64
CPU - Intel CORE i7
						CPU - Intel CORE i7
Looks like you don't have permission to delete the file "embree.dll". Maybe because it's in use?lighting_freak wrote: Thu Jan 25, 2018 10:11 am Another thing. I cant remove the current luxcore add-in.
Try deleting the BlendLuxCore folder manually in explorer.
edit: I tested BlendLuxCore-win64-opencl and it works fine here.
But I also had to remove the old addon folder manually because I got the same error as you.
Same here.B.Y.O.B. wrote: Thu Jan 25, 2018 12:16 pm edit: I tested BlendLuxCore-win64-opencl and it works fine here.
