Hi
I'm finding that when there is a value of -.01 in the Bump node's Bump Height, then the slider control for that value stops working, and if a new value is required it has to be typed in.
Thanks
Bump node-Slider control
Re: Bump node-Slider control
This property is defined like this:
https://github.com/LuxCoreRender/BlendL ... ump.py#L10
So -0.01 is the soft minimum, meaning the point where the slider ends. If you want values lower than this, you have to type them in manually.
This is because the value is in meters and when I wrote this code, I assumed that most bump heights will be in the range 0 to 1 cm, that's why I picked those as the end points of the slider.
# Allow negative values for inverting the bump. These values are in meters.
default_value = FloatProperty(default=0.001, soft_min=-0.01, soft_max=0.01,
precision=3,
subtype="DISTANCE", description="Bump height")This is because the value is in meters and when I wrote this code, I assumed that most bump heights will be in the range 0 to 1 cm, that's why I picked those as the end points of the slider.
BYOB
Thanks for the explanation.
So without the SHIFT key, then it will go from -.01 to .01 without any increments. Is that correct?
No, it should behave like a slider.
But thanks to you I noticed that this doesn't work because the default step is a lot larger than the range we are using here, so the value only jumps between -0.01 and 0.01 if you click and drag.
I specified a step of 1 mm, so it should now work like expected.
https://github.com/LuxCoreRender/BlendL ... c32c152ec4
By the way, if you encounter much different ranges in your work, you can also suggest different values for the soft_min and soft_max arguments.
Maybe it should be 5 cm instead of 1 cm?
That's great, thank you.
I don't think I need values outside the ones you have already specified.
I'm still on that learning curve, and having fun-thanks again.
