macOS: OpenCL device selection string has the wrong length, must be 2 instead of 1
Posted: Fri Oct 05, 2018 2:01 pm
by davorin
EHLO (o;
Just tried the latest standalone version under macOS 10.13.6 with a GTX1060....
After loading the LuxCore2.1Benchmark.bcf scene file I get at the end in the console:
Re: macOS: OpenCL device selection string has the wrong length, must be 2 instead of 1
Posted: Fri Oct 05, 2018 2:05 pm
I will fix the .bcf file.
Posted: Fri Oct 05, 2018 2:11 pm
by davorin
Hello
Is this similar to the Linux standalone version?
There it just gives me:
LuxCoreUI v2.0 (LuxCore demo:
http://www.luxcorerender.org)
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged.
RenderConfig loading error:
unsupported version
when I open the same file..
Posted: Fri Oct 05, 2018 2:15 pm
The benchmark scene was created with v2.1alpha3, try to open it with v2.1alpha4.
Posted: Fri Oct 05, 2018 2:18 pm
B.Y.O.B. wrote: ↑Fri Oct 05, 2018 2:15 pm
All serialized/binary formats are likely to change across different versions, just use text format instead of binary format if you want to work across different versions.
Posted: Fri Oct 05, 2018 2:23 pm
Alright.
Posted: Fri Oct 05, 2018 3:45 pm
Posted: Sat Oct 06, 2018 6:54 am
by davorin
Hmm...when opening the render.cfg file with LuxCore UI 2.1alpha4 I get under macOS 10.13.6 with GTX1060 and 387.10.10.10.40.105:
[LuxCore][98.275] [VignettingPlugin] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL
[LuxCore][98.275] [VignettingPlugin] Compiling kernels
[LuxCore][98.368] [VignettingPlugin] Kernels not cached
[LuxCore][98.368] [VignettingPlugin] Compiling VignettingPlugin_Apply Kernel
[LuxCore][98.368] [VignettingPlugin] Kernels compilation time: 93ms
[LuxRays][98.368] [Device GeForce GTX 1060 6GB Intersect] Gamma table buffer size: 16Kbytes
Abort trap: 6
and it crashes:
System Integrity Protection: enabled
Crashed Thread: 22 Dispatch queue: opencl_runtime
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Application Specific Signatures:
Graphics hardware encountered an error and was reset: 0x0000002b
Thread 0:: Dispatch queue: com.apple.main-thread
0 com.nvidia.web.GeForceGLDriverWeb 0x000000010bb5f0ea 0x10b7fe000 + 3543274
1 com.nvidia.web.GeForceGLDriverWeb 0x000000010bb55106 gldCreateBuffer + 218
2 libGFXShared.dylib 0x00007fff3b278058 gfxCreatePluginBuffer + 72
3 com.apple.opencl 0x00007fff3a09edf3 0x7fff3a065000 + 237043
4 com.apple.opencl 0x00007fff3a076f3c 0x7fff3a065000 + 73532
5 com.apple.opencl 0x00007fff3a084164 clCreateBuffer + 156
6 luxcoreui 0x0000000104616b79 0x103e9e000 + 7834489
7 luxcoreui 0x000000010458b44c 0x103e9e000 + 7263308
8 luxcoreui 0x0000000104513825 0x103e9e000 + 6772773
9 luxcoreui 0x0000000104338f55 0x103e9e000 + 4829013
10 luxcoreui 0x00000001042aa621 0x103e9e000 + 4245025
11 luxcoreui 0x00000001041dd54f 0x103e9e000 + 3405135
12 luxcoreui 0x00000001041ded87 0x103e9e000 + 3411335
13 luxcoreui 0x00000001042100b4 0x103e9e000 + 3612852
14 luxcoreui 0x000000010420ac06 0x103e9e000 + 3591174
15 luxcoreui 0x00000001041e0ba9 0x103e9e000 + 3419049
16 libdyld.dylib 0x00007fff5972c015 start + 1
Posted: Sat Oct 06, 2018 9:10 am
Could be caused by the OpenCL driver.
You can try to disable the OpenCL imagepipeline:
Open the file render.cfg, search for the line "film.opencl.enable" and write "= 0" instead of "= 1" behind it:
Then save the file and try again.
Posted: Sat Oct 06, 2018 9:19 am
by davorin
Exactly the same:
Crashed Thread: 20 Dispatch queue: opencl_runtime
abort() called
