Hi all,
I read about the noise aware sampling feature:
http://www.luxrender.net/wiki/LuxRender ... e_sampling
How do I turn it on?
I am getting very different noise levels in my scene, is that the feature I should use? Any other ideas?
Noise aware sampling
Re: Noise aware sampling
It is controlled by the "adaptive strength" setting. This value is a probability:
By default the sampler is noise-aware in 7 of 10 samples, and uniform in 3 of 10 samples.
If you use higher values the sampler focuses more on noisy areas, if you use lower values it samples the image more uniform.
