That worked, Thanks everybody!acasta69 wrote: ↑Mon Sep 17, 2018 5:05 pm If you need pyluxcoretools.exe, you can generate it after the build is completed with this command:You will then find a folder named "luxcorerender" containing all required files, including that one.Code: Select all
create-standalone.bat
Build LuxCore with Python version 3.6
