I am completely new to luxcore but i do use povray. In povray, i have scripts which generates thousands of orthographic images each with varying parameters.
I am missing a few things from povray and hoping luxcore can fill the gap:
1. I would like to be able to import CAD models into my scene.
2. I would like to use the GPU to accelerate rendering. I have an 8 GPU machine.
3. I would like if I could texture to my models but in a 3D sense. e.g. Adding texture to a perfect sphere results in the sphere's shawdow no longer being a perfect circle.
Are there any good tutorials translating from my povray workflow to lux?
Thanks in advance!
moving from povray to luxcore
- FarbigeWelt
- Contact:
Re: moving from povray to luxcore
Welcome avedis.
1) Are you familiar with Blender? What file format does your CAD export?
2) GPU is supported for path rendering. What amount of RAM do you have, main memory, graphic memory?
3) This should be avoidable
MacBook Air with M1
MacBook Air with M1
I guess you want to use LuxCore through the Python or C++ API?
Maybe this thread helps as a start: viewtopic.php?f=4&t=371
(I have linked a Python demo script there)
If you use the Python or C++ API, you can import your CAD models with a third-party importer, then you can pass the mesh to LuxCore.
This is not yet implemented in LuxCore.
You will have to either add the support yourself (in C++) or you have to do the displacement in your own script/program.
However, some of them are slightly outdated.
Unfortunately, there is no real beginner tutorial on the API usage yet.
But I currently have some free time, so maybe I can motivate myself to write one in the next week, and you can give me feedback if it's understandable
LuxCore can load PLY meshes, or you can pass arrays of vertices/faces directly from memory in your script.
This is the easiest of your requests
You mean displacement?
There are some samples here: https://github.com/LuxCoreRender/LuxCor ... er/samples
