Water absorption scattering values.
Sprocket
Post by Sprocket »
I remember back on the old luxrender forums there was a lot of info about scattering values taken from papers, or converted from papers. Unfortunately the internet archive of the forum site does not have those pages saved (unless i just didnt find a good snaphot)
I was wondering if anyone had some absorption and scattering values for water? I did at one stage, but Ive lost the blend files...
Also is there any plans or possibility to include a tabulated data texture in the future?
Sprocket
Re: Water absorption scattering values.
Post by Sprocket »
I found my old files hidden away on a hard drive.
Updated the scene for Luxcore. I did have to invert the absorption values though.
How did the 3D scene look like ? is it possible to get same result as the old one in luxcore ?
Sprocket
Post by Sprocket »
The scene is just a plane with ocean modifier applied to it, camera pointing straight up to the sky. I haven't been able to get any scene to render the same as old lux yet. Clamping might be affecting this scene, also I think there is a difference in the sky model used between the two.
Sprocket wrote: Tue Aug 14, 2018 9:20 am also I think there is a difference in the sky model used between the two.
The Preetham sky model was removed, it's only Hosek & Wilkie now.
However, that was also the default in old Lux, not sure if you mean this.
Sprocket
Post by Sprocket »
Yes that's what I was meaning, I could not remember what they were called :D
Sprocket
Post by Sprocket »
I tried it again with no clamping...
