ImportError: libOpenCL.so.1 when activating add-on
Posted: Tue Jul 10, 2018 2:40 pm
After installing Ubuntu 18.04 I had to re-install quite everything. For cuda there are unresolvable conflicts for packages. So I had to use install cuda-9-0 with run script.
After installing the luxcore file, when I try the activate the add-on I get a traceback from BlendLuxCore/__init__.py:
This file is in /usr/local/cuda-9.0/lib64/libOpenCL.so.1
and
/usr/local/cuda is linked to /usr/local/cuda-9.0
Also tried:
ln -s /usr/local/cuda-9.0/lib64/libOpenCL.so.1 /home/mick/.local/lib/python2.7/site-packages/
Where does blender / BlendLuxCore look for it? Which python installation does it use?
Suggestion on how to resolve the issue?
Thanks
and
Also tried:
Thanks
