ImportError: libOpenCL.so.1 when activating add-on
mick
Post by mick » Tue Jul 10, 2018 2:40 pm
After installing Ubuntu 18.04 I had to re-install quite everything. For cuda there are unresolvable conflicts for packages. So I had to use install cuda-9-0 with run script.
After installing the luxcore file, when I try the activate the add-on I get a traceback from BlendLuxCore/__init__.py:
This file is in /usr/local/cuda-9.0/lib64/libOpenCL.so.1
and
/usr/local/cuda is linked to /usr/local/cuda-9.0
Also tried:
ln -s /usr/local/cuda-9.0/lib64/libOpenCL.so.1 /home/mick/.local/lib/python2.7/site-packages/
Where does blender / BlendLuxCore look for it? Which python installation does it use?
Suggestion on how to resolve the issue?
Thanks
mick
Re: ImportError: libOpenCL.so.1 when activating add-on
Post by mick » Tue Jul 10, 2018 5:30 pm
solved it with
sudo apt install ocl-icd-opencl-dev
I feared that it would destroy my manual cuda installation. But it seems to work fine.
