Direct Light cache: hit rate not good
Re: Direct Light cache: hit rate not good
Post by Dade » Thu Jul 05, 2018 7:23 am
Can you redo test with the sun enabled ? I'm curious of the outcome.
Post by marcatore » Thu Jul 05, 2018 7:38 am
always with 1 sampling path?
So, I open the scene I shared, enable sun&sky and and stop?
Post by Dade » Thu Jul 05, 2018 7:40 am
Yes but with the fix to the number of light sources :mrgreen:
Post by B.Y.O.B. » Thu Jul 05, 2018 7:42 am
I'm currently rendering it with sun+sky and 5 diffuse/glossy/spec/total path depth.
edit: here it is.
Post by marcatore » Thu Jul 05, 2018 7:48 am
I'm already using the default value :)
Post by marcatore » Thu Jul 05, 2018 7:54 am
Here we are
This is with sun enabled 2min22sec (total time)
This is with double resolution (actually my daily output resolution) 33min total time ( total depth 8, diffuse&glossy&specular 4)
This is the denoised image
I'd like to save the lightcache solution, load it and render this scene with GPU.... :)
In any case a great improvement for this kind of scenarios.
Great job
edit: I didn't understand how to denoise the image with different settings after the render is finished. The "run denoiser" button is always grey (disabled)
Post by B.Y.O.B. » Thu Jul 05, 2018 8:19 am
Denoising after the render is finished is not possible.
I'd like to say "currently" but I fear it is not really solvable because of Blender API limitations (see https://github.com/LuxCoreRender/BlendL ... -398390095)
Post by marcatore » Thu Jul 05, 2018 8:27 am
So, if I'd like to test different settings, what should be the workflow?
Something like:
- launch render
- when I'm quite satisfied of the sampling, I press Pause of the render
- then in the image editor I change the denoiser settings
is it correct?
Post by Dade » Thu Jul 05, 2018 8:37 am
It works quite well, good.
I'm going to add the option to have persistent light cache, saved on file: for camera-only animations it will be possible to use the same cache for all frames. OpenCL support will be the next step once things are settle down.
Post by B.Y.O.B. » Thu Jul 05, 2018 8:44 am
Something like:
- launch render
is it correct?
Yes.
