Page 2 of 2
Re: Error after 17h rendering
Posted: Fri Jun 22, 2018 3:02 pm
by Asticles
Yeah, you're right, sorry, but the scene has nda and is about 2.4 GB without textures.
If I get this issue on another scene I will do it.
Thanks!
Posted: Mon Jun 25, 2018 6:06 am
by lighting_freak
I ran into that same issue after rendering some time continuous.
I've applied the patch and since then no scene won't start rendering anymore
I'm getting this error message:
AttributeError: 'LuxCoreScene' object has no attribute 'denoiser_log'
ERROR: 'LuxCoreScene' object has no attribute 'denoiser_log'
There is a sample scene but I believe it's not a scene issue:
Volume_absorption.blend
(519.48 KiB) Downloaded 181 times
Thanks for your help.
BR
Posted: Mon Jun 25, 2018 6:59 pm
You have probably applied the wrong patch, our you made a different mistake.
If you can't sort it out you will have to wait for the next alpha release.
Posted: Tue Jun 26, 2018 5:59 am
by lighting_freak
I've reinstalled BlendLuxCore 2.1 alpha 1 and apllied this patch only.
To this I've simply copied all the lines of "final.py" from github and replaced them in the installation folder.
Immediatly the same error appeared again. So I don't think that it is my mistake.
What's causing this "denoiser.log" message?
BR
Posted: Tue Jun 26, 2018 9:37 am
lighting_freak wrote: Tue Jun 26, 2018 5:59 am To this I've simply copied all the lines of "final.py" from github
That's your mistake. Only replace the red lines in the linked commit with the green lines in the commit, nothing else.
Posted: Wed Jun 27, 2018 8:46 am
by lighting_freak
I've tried to replace the lines first. After that complete Lux stopped working (I'm not a bit of a programmer).
Second was replacemetnt of complete file content. Lux was starting but with that denoiser.log message.
Third approach was cloning complete LuxBlend repository using SourceTree (and replacing complete LuxBlend files). Finally this is working.
BR
Posted: Wed Jun 27, 2018 9:11 am
lighting_freak wrote: Wed Jun 27, 2018 8:46 am Third approach was cloning complete LuxBlend repository using SourceTree (and replacing complete LuxBlend files). Finally this is working.
If you do this you also have to compile LuxCore yourself, otherwise it's not guaranteed to work.
See:
https://github.com/LuxCoreRender/BlendL ... -377352167
https://github.com/LuxCoreRender/BlendL ... -397807108
