Light
Posted: Fri Jun 15, 2018 9:17 pm
by Mark Oh
Hello
What is the reason that the light area and point do not want to shine at the same time.
Re: Light
Posted: Fri Jun 15, 2018 9:36 pm
by Mark Oh
Thank you I found in the wiki and turned off the automatic tone light. Tomorrow I will have a question about bump and normalmap.
Re: Light
Posted: Fri Jun 15, 2018 9:37 pm
More info please.
Show a render, your settings, and maybe upload a testscene that shows the problem.
Re: Light
Posted: Sat Jun 16, 2018 8:27 am
by Mark Oh
Hello
After entering normal map or nod normal map - no change in structure.
https://drive.google.com/file/d/13P38bK ... sp=sharing
https://drive.google.com/file/d/1Yvj7nA ... sp=sharing
Re: Light
Posted: Sat Jun 16, 2018 8:41 am
You have to enable the "Normalmap" checkbox on the imagemap node with the normalmap (bottom left).
I would recommend to delete the two disconnected nodes because the normalmap node is only needed in very very rare cases and for advanced users.
The "Normalmap" checkbox on the imagemap node is a shortcut.
These two node setups are equivalent:
Re: Light
Posted: Sat Jun 16, 2018 8:56 am
by Mark Oh
I did it - I do not see any difference
Re: Light
Posted: Sat Jun 16, 2018 9:23 am
Normalmaps should always use gamma 1.0 (this is another thing that the "Normalmap" checkbox does for you automatically).
You should also leave the imagemap brightness at 1.
However this probably does not fix your problem.
Can you upload the scene?
Please pack all textures with File -> External Data -> Pack all into .blend
Re: Light
Posted: Sat Jun 16, 2018 12:09 pm
by Mark Oh
Re: Light
Posted: Sat Jun 16, 2018 12:53 pm
You forgot to pack the textures.
At least the normalmap texture is not packed (some others are).
Re: Light
Posted: Sat Jun 16, 2018 2:18 pm
by Mark Oh
Ok, because there is no need in cycles and I never did it.
