Page 1 of 2
LuxBlend 2.1 alpha 1 - can't enable addon
Posted: Wed Jun 13, 2018 2:50 pm
by lighting_freak
Hello,
I've tried to update to LucBlend 2.1 alpha 1.
Tested the Blender internal update procedure without any success.
Tested also to download and install (copy) from github the OCL and non-OCL version.
Also the required redistributables are installed as described in the related thread.
The error message in all cases is that:
C:\Users\jantschek>C:\Users\jantschek\Desktop\blender.lnk
AL lib: (EE) ALCmmdevPlayback_resetProxy: Audio client returned buffer_len < per
iod*2; expect break up
found bundled python: C:\Program Files\Blender Foundation\Blender\2.79\python
  File "C:\Program Files\Blender Foundation\Blender\2.79\scripts\modules\addon_u
tils.py", line 331, in enable
    mod = __import__(module_name)
  File "C:\Users\jantschek\AppData\Roaming\Blender Foundation\Blender\2.79\scrip
ts\addons\BlendLuxCore\__init__.py", line 13, in <module>
    from .bin import pyluxcore
ImportError: DLL load failed: Das angegebene Modul wurde nicht gefunden.
I hope you could help me.
Thank you.
BR
Re: LuxBlend 2.1 alpha 1 - can't enable addon
Posted: Wed Jun 13, 2018 3:23 pm
by sarmath
Check this forum thread...i had the same problem....
viewtopic.php?f=4&t=404
Regards
Posted: Wed Jun 13, 2018 8:57 pm
by lighting_freak
I read that thread and I've installed the redistributables.
My issue seems to be somehow different.
BR
Posted: Tue Jun 19, 2018 4:52 pm
by lighting_freak
I'm using the machine that shows this issue in remote desktop mode only.
Might that be somehow the root cause of this issue?
BR
Posted: Tue Jun 19, 2018 7:56 pm
lighting_freak wrote: Tue Jun 19, 2018 4:52 pm I'm using the machine that shows this issue in remote desktop mode only.
OpenCL/OpenGL may have troubles working with remote desktop, does LuxMark work with remote desktop ? Have you tried to use the no-opencl version of BlendLuxCore ?
Posted: Wed Jun 20, 2018 9:57 am
by lighting_freak
Yes, I've tried the non-OCL version as well, without any success.
Could you tell me a source of LuxMark please?
I would like to contiune testing as suggested.
Thank you.
BR
Posted: Wed Jun 20, 2018 10:31 am
lighting_freak wrote: Wed Jun 20, 2018 9:57 am Yes, I've tried the non-OCL version as well, without any success.
This seems to suggest that the problem is not related to OpenCL. Are you using some Blender international setting (like international fonts or any not US/Western related setting) ?
lighting_freak wrote: Wed Jun 20, 2018 9:57 am Could you tell me a source of LuxMark please?
http://wiki.luxcorerender.org/LuxMark#Binaries
Posted: Sat Jun 30, 2018 12:45 pm
by frank_yifei
Check if you have microsoft visual c++ 2015 redistributables. it is required by python I think
Posted: Sat Jun 30, 2018 3:23 pm
by FiatLux
U sure you've installed this?
Dade wrote: Fri Jun 29, 2018 4:16 pm NOTE: due to a bug (https://github.com/embree/embree/issues/195) in Embree v3.2.0, you need to install also the Intel C++ redistribuibile (https://software.intel.com/sites/defaul ... .3.210.zip) on Windows
Posted: Wed Sep 05, 2018 7:36 am
by chx7
you need to update your graphic card, it worked for me ;) I almost went crazy :lol: :evil: , in the page of downloads not is clear about the installations, they should improve that.
