LuxBlend 2.1 alpha 1 - can't enable addon
lighting_freak
Post by lighting_freak » Wed Jun 13, 2018 2:50 pm
Hello,
I've tried to update to LucBlend 2.1 alpha 1.
Tested the Blender internal update procedure without any success.
Tested also to download and install (copy) from github the OCL and non-OCL version.
Also the required redistributables are installed as described in the related thread.
The error message in all cases is that:
C:\Users\jantschek>C:\Users\jantschek\Desktop\blender.lnk
AL lib: (EE) ALCmmdevPlayback_resetProxy: Audio client returned buffer_len < per
iod*2; expect break up
found bundled python: C:\Program Files\Blender Foundation\Blender\2.79\python
  File "C:\Program Files\Blender Foundation\Blender\2.79\scripts\modules\addon_u
tils.py", line 331, in enable
    mod = __import__(module_name)
  File "C:\Users\jantschek\AppData\Roaming\Blender Foundation\Blender\2.79\scrip
ts\addons\BlendLuxCore\__init__.py", line 13, in <module>
    from .bin import pyluxcore
ImportError: DLL load failed: Das angegebene Modul wurde nicht gefunden.
I hope you could help me.
Thank you.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
sarmath
Re: LuxBlend 2.1 alpha 1 - can't enable addon
Post by sarmath » Wed Jun 13, 2018 3:23 pm
Check this forum thread...i had the same problem....
viewtopic.php?f=4&t=404
Regards
Linux Mint 19 Tara i7 5820k 2xGTX 1070ti 16 GB RAM
lighting_freak
Post by lighting_freak » Wed Jun 13, 2018 8:57 pm
I read that thread and I've installed the redistributables.
My issue seems to be somehow different.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
lighting_freak
Post by lighting_freak » Tue Jun 19, 2018 4:52 pm
I'm using the machine that shows this issue in remote desktop mode only.
Might that be somehow the root cause of this issue?
BR
OS - Windows 7 X64
CPU - Intel CORE i7
Post by Dade » Tue Jun 19, 2018 7:56 pm
OpenCL/OpenGL may have troubles working with remote desktop, does LuxMark work with remote desktop ? Have you tried to use the no-opencl version of BlendLuxCore ?
lighting_freak
Post by lighting_freak » Wed Jun 20, 2018 9:57 am
Yes, I've tried the non-OCL version as well, without any success.
Could you tell me a source of LuxMark please?
I would like to contiune testing as suggested.
Thank you.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
Post by Dade » Wed Jun 20, 2018 10:31 am
This seems to suggest that the problem is not related to OpenCL. Are you using some Blender international setting (like international fonts or any not US/Western related setting) ?
http://wiki.luxcorerender.org/LuxMark#Binaries
frank_yifei
Post by frank_yifei » Sat Jun 30, 2018 12:45 pm
Check if you have microsoft visual c++ 2015 redistributables. it is required by python I think
FiatLux
Post by FiatLux » Sat Jun 30, 2018 3:23 pm
U sure you've installed this?
Dade wrote:
Fri Jun 29, 2018 4:16 pm
NOTE: due to a bug (https://github.com/embree/embree/issues/195) in Embree v3.2.0, you need to install also the Intel C++ redistribuibile (https://software.intel.com/sites/defaul ... .3.210.zip) on Windows
chx7
Post by chx7 » Wed Sep 05, 2018 7:36 am
you need to update your graphic card, it worked for me ;) I almost went crazy :lol: :evil: , in the page of downloads not is clear about the installations, they should improve that.
