what is the unit of the irradiance pass?
drsp
Post by drsp »
Hallo all,
I'm trying to get a physical value out of the irradiance map (blendluxcore 2.6).
Are the values is W/m²?
And how can I convert to lux?
The values of the irradiance path are changing if I alter the color temprature, but I can't find the right conversion to lux...
Can you give me a hint?
test01_step01.blend
(764.51 KiB) Downloaded 106 times
Re: what is the unit of the irradiance pass?
:? Doesn't it depend on settings as mentioned in Irradiance Contour?
drsp
Post by drsp »
As far as I can see it does not ...
I will run some more tests and come back with a more precise question ...
drsp
Post by drsp »
I prepared some test files and filed it as a bug: https://github.com/LuxCoreRender/LuxCore/issues/580
