blender 3.0 + Blendluxcore bugs
Just testing the 2.61 blendluxcore for blender 3.0 and will report bugs here :
1__ Blender 3.0 + blender 2.61 lastest dailys build crash when you click on the material
override slot. To reproduce just open blender 3.0 switch to luxcore engine and in view
layers properties click on material override slot:
Re: blender 3.0 + Blendluxcore bugs
Can't confirm this. Material Override is working fine here.
JulianoLisboa
Post by JulianoLisboa »
Here it also works well for me.
Luximage
Post by Luximage »
I have the same problem with Sharlybg, blender crashes.
windows 10, blendluxcore 2.61, blender 3.0
Luximage wrote: Sat Jan 22, 2022 11:53 am I have the same problem with Sharlybg, blender crashes.
Seem like a windows only issue. I have tested it on a second windows machine and it crash.
Luximage
Post by Luximage »
Just a simple scene that blender crashes if you try to choose an override material.
mat override crash.blend
(879.66 KiB) Downloaded 142 times
Again, doesn't crash.
Are you on windows ?
Sharlybg wrote: Sun Jan 23, 2022 8:48 am Are you on windows ?
Yes, W10.
Dez!
Post by Dez! »
If Luxcore is enabled in the Blender settings, Blender closes when you create a new scene. Linux, Manjaro, KDE
Here are the logs: https://pastebin.com/c1LfwEbN
