Installing OpenCL libraries
ajm
Post by ajm » Thu Jun 07, 2018 3:46 pm
Linux noob here, but had LuxCore running great until I upgraded the OS to Mint 19 and got a whole new set of proprietary drivers, but not sure if they contain the OpenCL drivers. nVidia 390.48-0ubuntu3. My error is
File "/home/andrew/opt/Blender/2.79/scripts/modules/addon_utils.py", line 331, in enable
mod = __import__(module_name)
File "/home/andrew/opt/Blender/2.79/scripts/addons/BlendLuxCore/__init__.py", line 13, in <module>
from .bin import pyluxcore
ImportError: libOpenCL.so.1: cannot open shared object file: No such file or directory
It appears that I am missing the OpenCL libraries, but have no clue how to add them. I have been searching for quite some time with no luck. I think the 384 version came with this library, since everything worked out of the box. Is there anyone that can help with this?
ajm
Re: Installing OpenCL libraries
Post by ajm » Thu Jun 07, 2018 4:20 pm
Found a bunch of OpenCL drivers, but not the file above. Installed compute drivers on top as well just to make sure, but no luck.
Don't know if this helps
andrew@andrew-desktop:~$ locate pyluxcore
/home/andrew/BlenderAdd_config/addons/BlendLuxCore/bin/pyluxcore.so
/home/andrew/opt/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so
/home/andrew/opt/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcoretools.zip
/home/andrew/opt/Blender/2.79/scripts/addons/BlendLuxCore/operators/pyluxcoretools.py
Post by Dade » Thu Jun 07, 2018 4:39 pm
AMD and NVIDIA drivers usually includes OpenCL support. I don't if Mint requires to install something else too (like OpenCL ICD) :?:
To check if your OpenCL platform is working fine, use LuxMark, it is simpler to run and it has been tested on many thousands of systems.
ajm
Post by ajm » Thu Jun 07, 2018 5:09 pm
Well I don't know how to run it. Downloaded and extracted the binaries and nothing is executing.
ajm
Post by ajm » Thu Jun 07, 2018 5:15 pm
It was the OpenCL ICD that I needed. Thanks!
