Area laser light missing in viewport render
Burk
Post by Burk » Thu Jun 07, 2018 8:57 am
Blender 2.79b, LuxCore 2.0
I have a project to show geometric optics with area laser light.
Here a sample for a laser from above meeting a glass slab:
That works fine with rendering (F12), but doesn't work with viewport rendering (Shift + Z).
s. blend-file attached
How can I get the preview in viewport rendering?
B.t.w. is there a description what exactly the parameters of volumes do? E.g. priority?
prism3 v4 Glasscheibe Detail.blend
(1.45 MiB) Downloaded 49 times
Re: Area laser light missing in viewport render
Post by B.Y.O.B. » Thu Jun 07, 2018 9:12 am
The viewport always uses the RT Path CPU engine, which is not able to compute the complicated light paths in your scene.
Not yet.
Volumes with a higher priority replace volumes with lower priority in areas where they overlap.
Post by B.Y.O.B. » Thu Jun 07, 2018 8:27 pm
Just remembered we actually have a wiki page about the volume settings thanks to Piita.
However, the priority parameter is not yet described there.
https://wiki.luxcorerender.org/LuxCoreRender_Volumes
