console denoise save file
zukazuka
Post by zukazuka » Fri Jun 01, 2018 1:15 am
When rendering from console ("batch render script") I select denoise on:
bpy.context.scene.luxcore.denoiser.enabled=True
The render is denoised but the result is saved as a separate pass "DENOISED" pass - it seems when I save image via:
bpy.data.images['Render Result'].save_render("out.png")
It only saves the "Combined" pass but not the Denoised image.
I haven't tried to figure out how to combine the passes via python - I thought I would ask first to see what your suggestion is to save the "DENOISED" pass when rendering from a command line batch render script?
Re: console denoise save file
Post by B.Y.O.B. » Fri Jun 01, 2018 7:37 am
You can save as multilayer EXR, this contains all the passes.
However it can only be opened by very few programs (one of them Blender).
Another option is to create a small compositing node setup where you pipe the outputs that should be saved into a file output node:
https://docs.blender.org/manual/en/dev/ ... /file.html
zukazuka
Post by zukazuka » Sun Jun 03, 2018 3:38 am
Here's what I wrote so far (seems to be working).
This script will save the denoised result automatically so if you are rendering on a server or batch processing - you can save the denoised version automatically:
import bpy
scene = bpy.context.scene
# make sure we have node tree
if scene.node_tree==None:
    scene.use_nodes=True
#if denoiser not enabled = no denoiser node output, so make sure it's enabled
if scene.node_tree:
    nodes = scene.node_tree.nodes
    auto_denoise_output_label="auto_denoise_save"
    # remove previously auto created denoise nodes to prevent duplicates
    for node in nodes:
        if node.label==auto_denoise_output_label:
            nodes.remove(node)
    render_layers = nodes.new("CompositorNodeRLayers")
    render_layers.location=(0,0)
    render_layers.label=auto_denoise_output_label
    output_file = nodes.new("CompositorNodeOutputFile")
    output_file.location=(200,0)
    output_file.inputs[0].name="filename"
    output_file.base_path = "/home/me/blender_output_path/"
    output_file.file_slots[0].path="filename"
    output_file.label=auto_denoise_output_label
    scene.node_tree.links.new(render_layers.outputs['DENOISED'],output_file.inputs[0])
