Flickering while rendering from different perspectives
Posted: Mon Sep 06, 2021 1:06 pm
Hello Together,
I have an issue, with rendering images of a static scene from different angles.
If i Rotate the camera around a lighting element there is some kind of flickering on the floor (See gif).
The setup is very somple (and also attaced): There is some led which is lighting up a volume. the light then reaches the floor, which is perfectly diffuse.
Because its diffuse the floor should be always the same brightness. But the brighness is different from different angles!
Does anyone have a clue whats causing this?
Thanks a lot for any kind of help!
Meinhard
Meinhard
