Dark edges on metal
Rivental
Dark edges on metal
Post by Rivental » Wed Sep 01, 2021 6:30 pm
Hello, I have a problem with the metal in luxcore.
How can I get rid of these dark edges?
I had the same problem in Cycles, but when I switched to multiscatter ggx in principled bsdf, the problem just gone.
I don't see the multiscatter ggx option in luxcore.
Luxcore
Luxcore
Cycles GGX
Cycles GGX
Cycles Multiscatter GGX
Re: Dark edges in metal
Post by Dade » Wed Sep 01, 2021 6:51 pm
The looks like a normal related problem (may a split normals is required). Can you post a test scene ?
Rivental
Post by Rivental » Wed Sep 01, 2021 7:25 pm
Yes, maybe this is problem with normals. But i don't understand why multiscatter ggx solves this problem.
https://drive.google.com/file/d/1MFND83 ... sp=sharing
Post by Dade » Tue Sep 07, 2021 11:08 am
The problem is in how your NURBS are exported to Lux. This is a part of the mesh exported:
As you can see, there are a lot of problems:
- very low triangles count;
- faceted;
- normals flipped (they point inside the object).
My suggestion is to transform the NURBS in triangle mesh inside Blender, so you have full control of what is going on and than render (i.e. export the scene) with LuxCore.
