Gradient (Blend) Texture
DionXein
Post by DionXein » Sun Aug 29, 2021 1:08 pm
Trying to make some procedural sci-fi element I got problem with gradient texture (Blender Blend).
And I can't understand, why it can use only world coordinates, not UV?
To solve this problem, I need to open external image redactor and create separate blend texture, which is a bit time consuming for so simple task.
(Maybe LuxCore texture set should be updated?)
Re: Gradient (Blend) Texture
Post by B.Y.O.B. » Sun Aug 29, 2021 1:51 pm
You can change the mapping type to UV or local.
DionXein
Post by DionXein » Sun Aug 29, 2021 7:17 pm
:!: Fair enough. Thank you :)
