luxcore 2.5 with intel igpu
drsp
Post by drsp »
Hello,
I'm just in the process to upgrade my systems from ubuntu 20.04 to 21.04.
With that comes blender 2.83.5 and I installed luxcore plugin v2.5.
With 2.4 I couldn't manage to use the internal GPU of my intel processors.
I gave it a try with 2.5 but the kernel compilation process crashes.
intel_opencl_icd is installed and clinfo gives meaningful output.
I'm attaching the log file. Can someone give me a hint to make this work?
Or is luxcore just not working with intels opencl drivers?
If so what's your recommendation for a well supported GPU (nvidia with RTX or amd with better FP64 performance)?
Thanks a lot,
Ingo
[LuxRays][123.529] [PathOCL kernel] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_PATHOCL -D PARAM_RAY_EPSILON_MIN=1e-05f -D PARAM_RAY_EPSILON_MAX=0.1f -D LUXCORE_GENERIC_OPENCL -D LUXRAYS_OPENCL_DEVICE -D LUXRAYS_OS_LINUX -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][123.529] [PathOCL kernel] Compiling kernels
Writing: /tmp/blender.crash.txt
# Blender 2.83.5, Unknown revision
bpy.context.space_data.context = 'RENDER'  # Property
bpy.context.scene.render.engine = 'LUXCORE'  # Property
bpy.context.scene.luxcore.config.device = 'OCL'  # Property
bpy.context.scene.luxcore.devices.devices[0].enabled = True  # Property
bpy.ops.object.select_all(action='DESELECT')  # Operator
bpy.context.scene.use_nodes = True  # Property
bpy.context.scene.use_nodes = False  # Property
bpy.context.area.ui_type = 'luxcore_material_nodes'  # Property
bpy.context.space_data.context = 'MATERIAL'  # Property
Compiling OPENCL kernels (just once, usually takes 15-30 minutes)  # Info
# backtrace
blender(BLI_system_backtrace+0x37) [0x56453b363677]
blender(+0xefbef1) [0x564538e18ef1]
/lib/x86_64-linux-gnu/libc.so.6(+0x41040) [0x7f65ed340040]
/lib/x86_64-linux-gnu/libigc.so.1(+0x3b70b3) [0x7f657c4cc0b3]
/lib/x86_64-linux-gnu/libigc.so.1(+0x3bfec3) [0x7f657c4d4ec3]
/lib/x86_64-linux-gnu/libLLVM-11.so.1(_ZN4llvm13FPPassManager13runOnFunctionERNS_8FunctionE+0x3b9) [0x7f659a3b00e9]
/lib/x86_64-linux-gnu/libLLVM-11.so.1(_ZN4llvm13FPPassManager11runOnModuleERNS_6ModuleE+0x33) [0x7f659a3b5693]
/lib/x86_64-linux-gnu/libLLVM-11.so.1(_ZN4llvm6legacy15PassManagerImpl3runERNS_6ModuleE+0x3e0) [0x7f659a3b0700]
/lib/x86_64-linux-gnu/libigc.so.1(+0x28eb61) [0x7f657c3a3b61]
/lib/x86_64-linux-gnu/libigc.so.1(+0x266b5a) [0x7f657c37bb5a]
/lib/x86_64-linux-gnu/libigc.so.1(+0x141aa6) [0x7f657c256aa6]
/lib/x86_64-linux-gnu/libigc.so.1(+0x1f7282) [0x7f657c30c282]
/usr/lib/x86_64-linux-gnu/intel-opencl/libigdrcl.so(+0x2ba2b7) [0x7f658410e2b7]
/usr/lib/x86_64-linux-gnu/intel-opencl/libigdrcl.so(+0xe40a1) [0x7f6583f380a1]
/usr/lib/x86_64-linux-gnu/intel-opencl/libigdrcl.so(+0x44e18) [0x7f6583e98e18]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxrays14oclKernelCache13ForcedCompileEP11_cl_contextP13_cl_device_idRKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaISB_EERKSB_PSB_+0xed) [0x7f658f0deebd]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxrays24oclKernelPersistentCache7CompileEP11_cl_contextP13_cl_device_idRKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaISB_EERKSB_PbPSB_+0x1ce8) [0x7f658f0e2df8]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxrays12OpenCLDevice14CompileProgramEPPNS_21HardwareDeviceProgramERKSt6vectorINSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEESaISA_EERKSA_SG_+0x16f3) [0x7f658f0d02b3]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN3slg26PathOCLBaseOCLRenderThread11InitKernelsEv+0x459) [0x7f658ede7b79]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN3slg26PathOCLBaseOCLRenderThread10InitRenderEv+0x457) [0x7f658ede3287]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN3slg26PathOCLBaseOCLRenderThread5StartEv+0x10) [0x7f658edd4180]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN3slg23PathOCLBaseRenderEngine13StartLockLessEv+0xf98) [0x7f658edcc548]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN3slg19PathOCLRenderEngine13StartLockLessEv+0x986) [0x7f658eb9ba76]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x56b5f1) [0x7f658eb365f1]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxcore6detail17RenderSessionImpl5StartEv+0x37) [0x7f658eabf877]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x5177b0) [0x7f658eae27b0]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(_ZN7luxcore15KernelCacheFillERKN7luxrays10PropertiesEPFvmmE+0x1dc) [0x7f658eae3bfc]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x47723b) [0x7f658ea4223b]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18be8c5) [0x7f658fe898c5]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18bea28) [0x7f658fe89a28]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18c4b03) [0x7f658fe8fb03]
/home/ingo/.config/blender/2.83/scripts/addons/BlendLuxCore/bin/pyluxcore.so(+0x18bc179) [0x7f658fe87179]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(_PyObject_MakeTpCall+0x94) [0x7f65ef937004]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(_PyEval_EvalFrameDefault+0x8811) [0x7f65ef8e8271]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(+0x1a98dc) [0x7f65efa168dc]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(_PyFunction_Vectorcall+0xa2) [0x7f65ef932132]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(+0xccd08) [0x7f65ef939d08]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(_PyEval_EvalFrameDefault+0x63b1) [0x7f65ef8e5e11]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(+0x71da3) [0x7f65ef8deda3]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(_PyEval_EvalFrameDefault+0x613b) [0x7f65ef8e5b9b]
/lib/x86_64-linux-gnu/libpython3.9.so.1.0(_PyEval_EvalFrameDefault+0x7070) [0x7f65ef8e6ad0]
blender(+0x151ae7d) [0x564539437e7d]
blender(+0x1483554) [0x5645393a0554]
blender(RE_engine_render+0x38e) [0x56453ade294e]
blender(+0x2ecf747) [0x56453adec747]
blender(+0x2ed2c28) [0x56453adefc28]
blender(RE_RenderFrame+0xf2) [0x56453adf0342]
blender(+0x1eda8d4) [0x564539df78d4]
blender(+0x11cbb26) [0x5645390e8b26]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x9450) [0x7f65f1d81450]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x43) [0x7f65ed416d53]
bestman8
Re: luxcore 2.5 with intel igpu
Post by bestman8 »
i can't really help with your issue but if you are looking for a new gpu pls go for nvidia a lot of render engines dont support amd or will stop the support in the near future.
intel GPUs not work really well for GPU render and in my experience crash most of the time.
