LuxcoreRender v2.5 error w/ Lenovo W530 Quardro K2000M -
3d_render_user
Post by 3d_render_user »
I am having problem getting LuxCoreRender to work with a w530 laptop fit with a Quadro K2000M .
Is there a way to force it to run in CPU mode?
LuxCoreUI v2.5 (LuxCore demo: http://www.luxcorerender.org)
Parsing LuxRender SDL file...
[SDL][5.672] Define ImageMap: NamedObject
[SDL][5.672] Material definition: ground
[SDL][5.672] Material definition: FreeCADMaterial_Lux_Pocket
[SDL][5.672] Camera type: perspective
[SDL][5.672] Camera position: Point[62.6413, -44.1115, -53.4127]
[SDL][5.672] Camera target: Point[17.7166, 1.94607, 31.4638]
[SDL][5.672] Camera clipping plane disabled
[SDL][5.672] Scene objects count: 2
[SDL][5.672] Light definition: LUXCORE_LIGHT_0_SUN2
[SDL][5.672] Light definition: LUXCORE_LIGHT_0_SKY2
[LuxCore][5.703] Configuration:
[LuxCore][5.703] opencl.platform.index = -1
[LuxCore][5.703] opencl.cpu.use = 0
[LuxCore][5.703] opencl.gpu.use = 1
[LuxCore][5.703] renderengine.type = "BIDIRCPU"
[LuxCore][5.703] sampler.type = "SOBOL"
[LuxCore][5.703] film.filter.type = "MITCHELL_SS"
[LuxCore][5.719] accelerator.instances.enable = 0
[LuxCore][5.719] path.maxdepth = 16
[LuxCore][5.719] light.maxdepth = 16
[LuxCore][5.719] film.filter.xwidth = 1
[LuxCore][5.719] film.filter.ywidth = 1
[LuxCore][5.719] film.filter.mitchell.B = 0.3333333
[LuxCore][5.719] film.filter.mitchell.C = 0.3333333
[LuxCore][5.719] film.width = 960
[LuxCore][5.719] film.height = 540
[LuxCore][5.719] film.imagepipeline.0.type = "TONEMAP_AUTOLINEAR"
[LuxCore][5.719] film.imagepipeline.1.type = "GAMMA_CORRECTION"
[LuxCore][5.719] film.imagepipeline.1.value = 2.2
[LuxCore][5.719] batch.halttime = 0
[LuxCore][5.719] batch.haltspp = 0
[LuxCore][5.719] File Name Resolver Configuration:
[LuxCore][5.719] .
[LuxCore][5.719] C:/Users/TestFile
[SDL][5.719] Camera type: perspective
[SDL][5.719] Camera position: Point[62.6413, -44.1115, -53.4127]
[SDL][5.719] Camera target: Point[17.7166, 1.94607, 31.4638]
[SDL][5.719] Camera clipping plane disabled
Film size adjusted: 960x540 (Frame buffer size: 960x540)
RenderConfig has cached kernels: True
[LuxCore][5.719] Film resolution: 960x540
[SDL][5.719] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][5.719] Image pipeline: film.imagepipeline
[SDL][5.719] Image pipeline step 0: TONEMAP_AUTOLINEAR
[SDL][5.719] Image pipeline step 1: GAMMA_CORRECTION
[LuxRays][5.719] OpenCL support: enabled
[LuxRays][5.750] OpenCL Platform 0: Intel(R) OpenCL
[LuxRays][5.765] OpenCL Platform 1: NVIDIA CUDA
[LuxRays][5.765] CUDA support: enabled
[LuxRays][5.765] CUDA support: available
[LuxRays][5.765] CUDA driver version: 9.10
[LuxRays][5.765] CUDA device count: 1
[LuxRays][5.765] Optix support: not available
[LuxRays][5.765] Device 0 name: Native
[LuxRays][5.765] Device 0 type: NATIVE_THREAD
[LuxRays][5.765] Device 0 compute units: 1
[LuxRays][5.765] Device 0 preferred float vector width: 4
[LuxRays][5.765] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][5.765] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][5.765] Device 0 has out of core memory support: 0
[LuxRays][5.765] Device 1 name: Intel(R) Core(TM) i7-3820QM CPU @ 2.70GHz
[LuxRays][5.765] Device 1 type: OPENCL_CPU
[LuxRays][5.765] Device 1 compute units: 8
[LuxRays][5.765] Device 1 preferred float vector width: 8
[LuxRays][5.765] Device 1 max allocable memory: 7758MBytes
[LuxRays][5.765] Device 1 max allocable memory block size: 1939MBytes
[LuxRays][5.765] Device 1 has out of core memory support: 0
[LuxRays][5.765] Device 2 name: Intel(R) HD Graphics 4000
[LuxRays][5.765] Device 2 type: OPENCL_GPU
[LuxRays][5.765] Device 2 compute units: 16
[LuxRays][5.765] Device 2 preferred float vector width: 1
[LuxRays][5.765] Device 2 max allocable memory: 1400MBytes
[LuxRays][5.765] Device 2 max allocable memory block size: 350MBytes
[LuxRays][5.765] Device 2 has out of core memory support: 0
[LuxRays][5.765] Device 3 name: Quadro K2000M
[LuxRays][5.765] Device 3 type: OPENCL_GPU
[LuxRays][5.781] Device 3 compute units: 2
[LuxRays][5.781] Device 3 preferred float vector width: 1
[LuxRays][5.781] Device 3 max allocable memory: 2048MBytes
[LuxRays][5.781] Device 3 max allocable memory block size: 512MBytes
[LuxRays][5.781] Device 3 has out of core memory support: 0
[LuxRays][5.781] Device 4 name: Quadro K2000M
[LuxRays][5.781] Device 4 type: CUDA_GPU
[LuxRays][5.781] Device 4 compute units: 192
[LuxRays][5.781] Device 4 preferred float vector width: 1
[LuxRays][5.781] Device 4 max allocable memory: 2048MBytes
[LuxRays][5.781] Device 4 max allocable memory block size: 17592186044415MBytes
[LuxRays][5.781] Device 4 has out of core memory support: 1
[LuxRays][5.781] Device 4 CUDA compute capability: 3.0
[LuxRays][5.781] Creating 8 intersection device(s)
[LuxRays][5.781] Allocating intersection device 0: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 1: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxCore][5.781] Configuring 8 CPU render threads
[LuxRays][5.781] Preprocessing DataSet
[LuxRays][5.781] Total vertex count: 410
[LuxRays][5.781] Total triangle count: 390
[LuxRays][5.781] Preprocessing DataSet done
[LuxRays][5.781] Adding DataSet accelerator: EMBREE
[LuxRays][5.797] EmbreeAccel build time: 16ms
[LuxCore][5.875] Film hardware image pipeline
[LuxCore][5.937] Film hardware device used: Quadro K2000M CUDAIntersect (Type: CUDA_GPU)
[LuxRays][5.937] [Device Quadro K2000M CUDAIntersect] IMAGEPIPELINE buffer size: 6075Kbytes
[LuxRays][5.937] [Device Quadro K2000M CUDAIntersect] Merge buffer size: 8100Kbytes
[LuxRays][5.937] [MergeSampleBuffersOCL] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D LUXRAYS_CUDA_DEVICE -D LUXRAYS_OS_WINDOWS --use_fast_math
[LuxRays][5.937] [MergeSampleBuffersOCL] Compiling kernels
[LuxCore][5.969] [Quadro K2000M CUDAIntersect] Memory used for hardware image pipeline: 14175Kbytes
RUNTIME ERROR: CUDA driver API error CUDA_ERROR_INVALID_PTX (code: 218, file:D:\a\1\Luxcore\src\luxrays\utils\cuda.cpp, line: 247): a PTX JIT compilation failed
3d_render_user
Re: LuxcoreRender v2.5 error w/ Lenovo W530 Quardro K2000M -
i tried to attach the scene file .lxs but it wouldn't let me.
here is the content:
# Main Scene File
Renderer "sampler"
Sampler "lowdiscrepancy"
"integer pixelsamples" [16]
"string pixelsampler" ["lowdiscrepancy"]
"bool noiseaware" ["false"]
Accelerator "qbvh"
SurfaceIntegrator "bidirectional"
"integer eyedepth" [16]
"integer lightdepth" [16]
"integer lightraycount" [1]
"string lightpathstrategy" ["auto"]
"string lightstrategy" ["auto"]
VolumeIntegrator "single"
PixelFilter "mitchell"
"bool supersample" ["true"]
"float B" [0.333333343267441]
"float C" [0.333333343267441]
"float xwidth" [2.000000000000000]
"float ywidth" [2.000000000000000]
# declares position and view direction
# Generated by FreeCAD (http://www.freecadweb.org/)
LookAt 62.6413 -44.1115 -53.4127 17.7166 1.94607 31.4638 0.213758 -0.806728 0.550906
Camera "perspective"
"float fov" [49.134342077604479]
"float screenwindow" [-1.000000000000000 1.000000000000000 -0.562500000000000 0.562500000000000]
"bool autofocus" ["false"]
"float shutteropen" [0.000000000000000]
"float shutterclose" [0.041666666666667]
Film "fleximage"
"integer xresolution" [960]
"integer yresolution" [540]
"float gamma" [2.200000000000000]
"float colorspace_white" [0.314275000000000 0.329411000000000]
"float colorspace_red" [0.630000000000000 0.340000000000000]
"float colorspace_green" [0.310000000000000 0.595000000000000]
"float colorspace_blue" [0.155000000000000 0.070000000000000]
"string filename" ["outdoor.Scene.00001"]
"bool write_resume_flm" ["false"]
"bool restart_resume_flm" ["false"]
"bool write_flm_direct" ["false"]
"bool write_exr_halftype" ["false"]
"bool write_exr_applyimaging" ["true"]
"bool write_exr_ZBuf" ["false"]
"string write_exr_compressiontype" ["PIZ (lossless)"]
"string write_exr_zbuf_normalizationtype" ["None"]
"bool write_exr" ["false"]
"string write_exr_channels" ["RGB"]
"bool write_png" ["true"]
"string write_png_channels" ["RGB"]
"bool write_png_16bit" ["false"]
"bool write_tga" ["false"]
"string write_tga_channels" ["RGB"]
"string ldr_clamp_method" ["cut"]
"integer displayinterval" [10]
"integer writeinterval" [180]
"integer flmwriteinterval" [900]
"integer outlierrejection_k" [2]
"integer tilecount" [0]
"string tonemapkernel" ["autolinear"]
WorldBegin
# Materials File
MakeNamedMaterial "ground"
"float uroughness" [0.075000002980232]
"float vroughness" [0.075000002980232]
"string name" ["amorphous carbon"]
"string type" ["metal"]
# Geometry File
# declares FreeCAD objects
MakeNamedMaterial "FreeCADMaterial_Lux_Pocket"
"color Kd" [0.8 0.8 0.8]
"float sigma" [0.000000000000000]
"string type" ["matte"]
AttributeBegin # "Lux_Pocket"
Transform [1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1]
Shape "mesh"
"integer triindices" [21 20 31 22 21 31 23 22 31 24 23 31 25 24 31 26 25 31 27 26 31 28 27 31 29 28 31 31 20 19 32 31 18 31 19 18 33 32 17 32 18 17 34 33 16 33 17 16 35 34 15 34 16 15 1 0 30 2 1 30 3 2 30 4 3 30 5 4 30 5 30 6 36 35 14 35 15 14 6 30 7 37 36 13 36 14 13 7 30 8 38 37 12 37 13 12 8 30 9 38 12 11 30 38 11 9 30 10 30 11 10 76 111 114 76 114 77 77 114 113 77 113 78 78 113 112 39 41 40 112 40 79 78 112 79 79 40 80 40 41 80 41 42 81 80 41 81 42 43 82 81 42 82 43 44 83 82 43 83 44 45 84 83 44 84 45 46 85 84 45 85 46 47 86 85 46 86 47 48 87 86 47 87 48 49 88 87 48 88 49 50 89 88 49 89 50 51 90 89 50 90 51 52 91 90 51 91 52 53 92 91 52 92 53 54 93 92 53 93 54 55 94 55 56 94 93 54 94 56 57 95 94 56 95 57 58 96 95 57 96 58 59 97 96 58 97 59 60 98 97 59 98 60 61 99 98 60 99 61 62 100 99 61 100 62 63 101 100 62 101 63 64 102 101 63 102 64 65 103 102 64 103 65 66 104 103 65 104 66 67 105 104 66 105 67 68 106 105 67 106 106 68 107 107 68 70 68 69 70 107 70 108 108 70 74 108 74 109 109 74 73 109 73 110 73 72 110 110 72 75 72 71 75 115 117 116 117 118 116 119 128 120 128 129 120 129 130 121 130 131 121 120 129 121 121 131 122 131 132 123 122 131 123 132 133 124 133 134 124 123 132 124 124 134 125 134 135 126 135 136 126 125 134 126 126 136 127 137 139 138 139 140 138 155 156 154 156 157 154 157 158 154 158 141 154 153 154 152 150 151 149 151 152 149 152 154 149 141 142 146 142 143 146 143 144 146 144 145 146 147 148 146 148 149 146 154 141 146 149 154 146 180 181 210 181 182 211 182 183 211 210 181 211 179 180 209 180 210 209 183 184 212 211 183 212 177 178 208 178 179 208 179 209 208 184 185 213 212 184 213 176 177 207 177 208 207 185 186 214 186 187 214 213 185 214 176 207 206 174 175 206 175 176 206 187 188 215 214 187 215 174 206 205 174 205 173 215 188 216 188 189 216 173 205 204 173 204 172 216 189 217 217 189 190 172 204 203 172 203 171 217 190 191 218 217 191 171 203 170 203 202 170 218 191 192 219 218 192 202 201 169 170 202 169 219 192 193 194 219 193 201 200 168 169 201 168 194 193 159 168 200 167 195 194 160 194 159 160 200 199 166 167 200 166 196 195 161 195 160 161 199 198 165 166 199 165 197 196 162 196 161 162 198 197 164 165 198 164 164 197 163 197 162 163 220 221 249 248 220 249 221 222 250 249 221 250 222 223 251 250 222 251 223 224 252 224 225 252 251 223 252 252 225 253 225 226 254 253 225 254 226 227 255 227 228 255 254 226 255 228 229 256 255 228 256 256 229 257 229 230 258 257 229 258 258 230 259 230 231 259 259 231 260 231 232 260 232 233 260 260 233 261 233 234 262 261 233 262 234 235 262 262 235 263 235 236 264 236 237 264 263 235 264 237 238 265 264 237 265 238 239 266 265 238 266 266 239 267 239 240 268 240 241 268 267 239 268 268 241 269 241 242 270 269 241 270 242 243 271 270 242 271 243 244 272 271 243 272 244 245 273 272 244 273 245 246 247 273 245 247 290 291 317 316 290 317 289 290 315 290 316 315 291 292 318 317 291 318 288 289 314 289 315 314 292 293 319 293 294 319 318 292 319 286 287 313 287 288 313 288 314 313 319 294 320 286 313 312 294 295 321 320 294 321 285 286 311 286 312 311 295 296 322 321 295 322 284 285 310 285 311 310 322 296 297 323 322 297 284 310 309 284 309 283 283 309 308 323 297 298 324 323 298 283 308 282 324 298 299 325 324 299 282 308 281 308 307 281 325 299 274 300 325 274 306 305 280 307 306 280 281 307 280 300 274 275 301 300 275 302 301 275 280 305 279 302 275 276 305 304 278 279 305 278 303 302 277 304 303 277 302 276 277 278 304 277 326 327 355 327 328 355 354 326 355 355 328 356 328 329 357 329 330 357 356 328 357 330 331 358 357 330 358 358 331 359 331 332 360 359 331 360 332 333 361 333 334 361 360 332 361 361 334 362 334 335 363 362 334 363 335 336 364 363 335 364 364 336 365 336 337 365 365 337 366 337 338 366 366 338 367 338 339 367 367 339 368 339 340 368 340 341 368 368 341 369 341 342 370 369 341 370 342 343 371 343 344 371 370 342 371 344 345 372 371 344 372 345 346 373 372 345 373 373 346 374 346 347 375 347 348 375 374 346 375 375 348 376 348 349 377 349 350 377 376 348 377 377 350 378 350 351 379 351 352 379 378 350 379 379 352 353 395 396 398 396 397 398 394 395 393 398 399 401 399 400 401 392 393 391 401 402 403 398 401 403 395 398 404 393 395 404 398 403 404 388 389 387 389 390 387 390 391 387 404 405 380 380 381 383 381 382 383 384 385 383 385 386 383 386 387 383 391 393 383 393 404 383 404 380 383 387 391 383 ]
"point P" [10.0871 -6.5 7.21645e-15 8.78351 -8.17618 9.07738e-15 7.20487 -9.59634 1.06541e-14 5.40063 -10.716 1.18972e-14 3.42729 -11.5002 1.27677e-14 1.34663 -11.9242 1.32385e-14 -0.776203 -11.9749 1.32948e-14 -2.87473 -11.6506 1.29347e-14 -4.88324 -10.9615 1.21697e-14 -6.73884 -9.92915 1.10236e-14 -8.38344 -8.58592 9.53229e-15 -9.76553 -6.97384 7.74252e-15 -10.8418 -5.1434 5.71032e-15 -11.5787 -3.1519 3.49932e-15 -11.9529 -1.06172 1.17874e-15 -11.9529 1.06172 -1.17874e-15 -11.5787 3.1519 -3.49932e-15 -10.8418 5.1434 -5.71032e-15 -9.76553 6.97384 -7.74252e-15 -8.38344 8.58592 -9.53229e-15 -6.73884 9.92915 -1.10236e-14 -4.88324 10.9615 -1.21697e-14 -2.87473 11.6506 -1.29347e-14 -0.776203 11.9749 -1.32948e-14 1.34663 11.9242 -1.32385e-14 3.42729 11.5002 -1.27677e-14 5.40063 10.716 -1.18972e-14 7.20487 9.59634 -1.06541e-14 8.78351 8.17618 -9.07738e-15 10.0871 6.5 -7.21645e-15 -6.22495 -6.5 8.54872e-15 -6.22495 6.5 -8.54872e-15 -7.4012 5.12076 -5.68519e-15 -8.27721 3.5338 -3.9233e-15 -8.81745 1.80348 -2.00226e-15 -9 9.45973e-15 -1.11581e-29 -8.81745 -1.80348 2.00226e-15 -8.27721 -3.5338 3.9233e-15 -7.4012 -5.12076 5.68519e-15 10.0871 -6.5 7.21645e-15 10.0871 -6.5 18 8.78351 -8.17618 9.07738e-15 7.20487 -9.59634 1.06541e-14 5.40063 -10.716 1.18972e-14 3.42729 -11.5002 1.27677e-14 1.34663 -11.9242 1.32385e-14 -0.776203 -11.9749 1.32948e-14 -2.87473 -11.6506 1.29347e-14 -4.88324 -10.9615 1.21697e-14 -6.73884 -9.92915 1.10236e-14 -8.38344 -8.58592 9.53229e-15 -9.76553 -6.97384 7.74252e-15 -10.8418 -5.1434 5.71032e-15 -11.5787 -3.1519 3.49932e-15 -11.9529 -1.06172 1.17874e-15 -11.9529 1.06172 -1.17874e-15 -11.5787 3.1519 -3.49932e-15 -10.8418 5.1434 -5.71032e-15 -9.76553 6.97384 -7.74252e-15 -8.38344 8.58592 -9.53229e-15 -6.73884 9.92915 -1.10236e-14 -4.88324 10.9615 -1.21697e-14 -2.87473 11.6506 -1.29347e-14 -0.776203 11.9749 -1.32948e-14 1.34663 11.9242 -1.32385e-14 3.42729 11.5002 -1.27677e-14 5.40063 10.716 -1.18972e-14 7.20487 9.59634 -1.06541e-14 8.78351 8.17618 -9.07738e-15 10.0871 6.5 -7.21645e-15 10.0871 6.5 18 12 1.9984e-14 18 11.8773 1.7114 18 11.5119 3.38781 18 10.911 4.99497 18 12 2.55351e-14 23 12 2.55351e-14 23 11.8072 -2.14268 23 11.2348 -4.2165 23 10.3014 -6.15479 23 9.03686 -7.89526 23 7.48188 -9.38198 23 5.68642 -10.5671 23 3.7082 -11.4127 23 1.6108 -11.8914 23 -0.538378 -11.9879 23 -2.67025 -11.6991 23 -4.7163 -11.0343 23 -6.61076 -10.0149 23 -8.29275 -8.67354 23 -9.7082 -7.05342 23 -10.8116 -5.2066 23 -11.5676 -3.19244 23 -11.9517 -1.07567 23 -11.9517 1.07567 23 -11.5676 3.19244 23 -10.8116 5.2066 23 -9.7082 7.05342 23 -8.29275 8.67354 23 -6.61076 10.0149 23 -4.7163 11.0343 23 -2.67025 11.6991 23 -0.538378 11.9879 23 1.6108 11.8914 23 3.7082 11.4127 23 5.68642 10.5671 23 7.48188 9.38198 23 9.03686 7.89526 23 10.3014 6.15479 23 11.2348 4.2165 23 11.8072 2.14268 23 12 1.9984e-14 18 10.911 -4.99497 18 11.5119 -3.38781 18 11.8773 -1.7114 18 10.0871 6.5 18 -6.22495 6.5 18 10.0871 6.5 -7.21645e-15 -6.22495 6.5 -8.54872e-15 -6.22495 6.5 18 -7.4012 5.12076 18 -8.27721 3.5338 18 -8.81745 1.80348 18 -9 2.94437e-14 18 -8.81745 -1.80348 18 -8.27721 -3.5338 18 -7.4012 -5.12076 18 -6.22495 -6.5 18 -6.22495 6.5 -8.54872e-15 -7.4012 5.12076 -5.68519e-15 -8.27721 3.5338 -3.9233e-15 -8.81745 1.80348 -2.00226e-15 -9 9.45973e-15 -1.11581e-29 -8.81745 -1.80348 2.00226e-15 -8.27721 -3.5338 3.9233e-15 -7.4012 -5.12076 5.68519e-15 -6.22495 -6.5 8.54872e-15 -6.22495 -6.5 18 10.0871 -6.5 18 -6.22495 -6.5 8.54872e-15 10.0871 -6.5 7.21645e-15 12 1.9984e-14 18 11.8773 1.7114 18 11.5119 3.38781 18 10.911 4.99497 18 10.0871 6.5 18 -6.22495 6.5 18 -7.4012 5.12076 18 -8.27721 3.5338 18 -8.81745 1.80348 18 -9 2.94437e-14 18 -8.81745 -1.80348 18 -8.27721 -3.5338 18 -7.4012 -5.12076 18 -6.22495 -6.5 18 10.0871 -6.5 18 10.911 -4.99497 18 11.5119 -3.38781 18 11.8773 -1.7114 18 12 2.55351e-14 23 11.8072 -2.14268 23 11.2348 -4.2165 23 10.3014 -6.15479 23 9.03686 -7.89526 23 7.48188 -9.38198 23 5.68642 -10.5671 23 3.7082 -11.4127 23 1.6108 -11.8914 23 -0.538378 -11.9879 23 -2.67025 -11.6991 23 -4.7163 -11.0343 23 -6.61076 -10.0149 23 -8.29275 -8.67354 23 -9.7082 -7.05342 23 -10.8116 -5.2066 23 -11.5676 -3.19244 23 -11.9517 -1.07567 23 -11.9517 1.07567 23 -11.5676 3.19244 23 -10.8116 5.2066 23 -9.7082 7.05342 23 -8.29275 8.67354 23 -6.61076 10.0149 23 -4.7163 11.0343 23 -2.67025 11.6991 23 -0.538378 11.9879 23 1.6108 11.8914 23 3.7082 11.4127 23 5.68642 10.5671 23 7.48188 9.38198 23 9.03686 7.89526 23 10.3014 6.15479 23 11.2348 4.2165 23 11.8072 2.14268 23 6.5 2.55351e-14 23 6.31112 -1.55555 23 5.75546 -3.0207 23 4.86532 -4.3103 23 3.69242 -5.3494 23 2.30493 -6.07761 23 0.783488 -6.45261 23 -0.783488 -6.45261 23 -2.30493 -6.07761 23 -3.69242 -5.3494 23 -4.86532 -4.3103 23 -5.75546 -3.0207 23 -6.31112 -1.55555 23 -6.5 1.89659e-14 23 -6.31112 1.55555 23 -5.75546 3.0207 23 -4.86532 4.3103 23 -3.69242 5.3494 23 -2.30493 6.07761 23 -0.783488 6.45261 23 0.783488 6.45261 23 2.30493 6.07761 23 3.69242 5.3494 23 4.86532 4.3103 23 5.75546 3.0207 23 6.31112 1.55555 23 6.5 2.55351e-14 23 6.31112 -1.55555 23 5.75546 -3.0207 23 4.86532 -4.3103 23 3.69242 -5.3494 23 2.30493 -6.07761 23 0.783488 -6.45261 23 -0.783488 -6.45261 23 -2.30493 -6.07761 23 -3.69242 -5.3494 23 -4.86532 -4.3103 23 -5.75546 -3.0207 23 -6.31112 -1.55555 23 -6.5 1.89659e-14 23 -6.31112 1.55555 23 -5.75546 3.0207 23 -4.86532 4.3103 23 -3.69242 5.3494 23 -2.30493 6.07761 23 -0.783488 6.45261 23 0.783488 6.45261 23 2.30493 6.07761 23 3.69242 5.3494 23 4.86532 4.3103 23 5.75546 3.0207 23 6.31112 1.55555 23 6.5 2.55351e-14 23 6.5 4.21885e-14 38 6.5 4.21885e-14 38 6.31112 -1.55555 38 5.75546 -3.0207 38 4.86532 -4.3103 38 3.69242 -5.3494 38 2.30493 -6.07761 38 0.783488 -6.45261 38 -0.783488 -6.45261 38 -2.30493 -6.07761 38 -3.69242 -5.3494 38 -4.86532 -4.3103 38 -5.75546 -3.0207 38 -6.31112 -1.55555 38 -6.5 3.56193e-14 38 -6.31112 1.55555 38 -5.75546 3.0207 38 -4.86532 4.3103 38 -3.69242 5.3494 38 -2.30493 6.07761 38 -0.783488 6.45261 38 0.783488 6.45261 38 2.30493 6.07761 38 3.69242 5.3494 38 4.86532 4.3103 38 5.75546 3.0207 38 6.31112 1.55555 38 6.5 4.21885e-14 38 6.31112 -1.55555 38 5.75546 -3.0207 38 4.86532 -4.3103 38 3.69242 -5.3494 38 2.30493 -6.07761 38 0.783488 -6.45261 38 -0.783488 -6.45261 38 -2.30493 -6.07761 38 -3.69242 -5.3494 38 -4.86532 -4.3103 38 -5.75546 -3.0207 38 -6.31112 -1.55555 38 -6.5 3.56193e-14 38 -6.31112 1.55555 38 -5.75546 3.0207 38 -4.86532 4.3103 38 -3.69242 5.3494 38 -2.30493 6.07761 38 -0.783488 6.45261 38 0.783488 6.45261 38 2.30493 6.07761 38 3.69242 5.3494 38 4.86532 4.3103 38 5.75546 3.0207 38 6.31112 1.55555 38 4.25 4.21885e-14 38 4.1265 -1.01709 38 3.76319 -1.97507 38 3.18117 -2.81827 38 2.41428 -3.49768 38 1.50707 -3.97382 38 0.512281 -4.21901 38 -0.512281 -4.21901 38 -1.50707 -3.97382 38 -2.41428 -3.49768 38 -3.18117 -2.81827 38 -3.76319 -1.97507 38 -4.1265 -1.01709 38 -4.25 3.78932e-14 38 -4.1265 1.01709 38 -3.76319 1.97507 38 -3.18117 2.81827 38 -2.41428 3.49768 38 -1.50707 3.97382 38 -0.512281 4.21901 38 0.512281 4.21901 38 1.50707 3.97382 38 2.41428 3.49768 38 3.18117 2.81827 38 3.76319 1.97507 38 4.1265 1.01709 38 4.25 4.21885e-14 38 4.1265 -1.01709 38 3.76319 -1.97507 38 3.18117 -2.81827 38 2.41428 -3.49768 38 1.50707 -3.97382 38 0.512281 -4.21901 38 -0.512281 -4.21901 38 -1.50707 -3.97382 38 -2.41428 -3.49768 38 -3.18117 -2.81827 38 -3.76319 -1.97507 38 -4.1265 -1.01709 38 -4.25 3.78932e-14 38 -4.1265 1.01709 38 -3.76319 1.97507 38 -3.18117 2.81827 38 -2.41428 3.49768 38 -1.50707 3.97382 38 -0.512281 4.21901 38 0.512281 4.21901 38 1.50707 3.97382 38 2.41428 3.49768 38 3.18117 2.81827 38 3.76319 1.97507 38 4.1265 1.01709 38 4.25 4.21885e-14 38 4.25 5.55112e-14 50 4.25 5.55112e-14 50 4.1265 -1.01709 50 3.76319 -1.97507 50 3.18117 -2.81827 50 2.41428 -3.49768 50 1.50707 -3.97382 50 0.512281 -4.21901 50 -0.512281 -4.21901 50 -1.50707 -3.97382 50 -2.41428 -3.49768 50 -3.18117 -2.81827 50 -3.76319 -1.97507 50 -4.1265 -1.01709 50 -4.25 5.12159e-14 50 -4.1265 1.01709 50 -3.76319 1.97507 50 -3.18117 2.81827 50 -2.41428 3.49768 50 -1.50707 3.97382 50 -0.512281 4.21901 50 0.512281 4.21901 50 1.50707 3.97382 50 2.41428 3.49768 50 3.18117 2.81827 50 3.76319 1.97507 50 4.1265 1.01709 50 4.25 5.55112e-14 50 4.1265 -1.01709 50 3.76319 -1.97507 50 3.18117 -2.81827 50 2.41428 -3.49768 50 1.50707 -3.97382 50 0.512281 -4.21901 50 -0.512281 -4.21901 50 -1.50707 -3.97382 50 -2.41428 -3.49768 50 -3.18117 -2.81827 50 -3.76319 -1.97507 50 -4.1265 -1.01709 50 -4.25 5.12159e-14 50 -4.1265 1.01709 50 -3.76319 1.97507 50 -3.18117 2.81827 50 -2.41428 3.49768 50 -1.50707 3.97382 50 -0.512281 4.21901 50 0.512281 4.21901 50 1.50707 3.97382 50 2.41428 3.49768 50 3.18117 2.81827 50 3.76319 1.97507 50 4.1265 1.01709 50 ]
"normal N" [-0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 -0 -1.11022e-15 -1 0.840593 -0.541667 6.01371e-16 0.840593 -0.541667 6.01371e-16 0.731959 -0.681348 7.56448e-16 0.600406 -0.799695 8.8784e-16 0.450053 -0.893002 9.91431e-16 0.285607 -0.958347 1.06398e-15 0.112219 -0.993684 1.10321e-15 -0.0646836 -0.997906 1.1079e-15 -0.239561 -0.970881 1.07789e-15 -0.406936 -0.913457 1.01414e-15 -0.56157 -0.827429 9.18631e-16 -0.69862 -0.715493 7.94357e-16 -0.813794 -0.581154 6.4521e-16 -0.903486 -0.428617 4.7586e-16 -0.964889 -0.262659 2.9161e-16 -0.996078 -0.0884764 9.82285e-17 -0.996078 0.0884764 -9.82285e-17 -0.964889 0.262659 -2.9161e-16 -0.903486 0.428617 -4.7586e-16 -0.813794 0.581154 -6.4521e-16 -0.69862 0.715493 -7.94357e-16 -0.56157 0.827429 -9.18631e-16 -0.406936 0.913457 -1.01414e-15 -0.239561 0.970881 -1.07789e-15 -0.0646836 0.997906 -1.1079e-15 0.112219 0.993684 -1.10321e-15 0.285607 0.958347 -1.06398e-15 0.450053 0.893002 -9.91431e-16 0.600406 0.799695 -8.8784e-16 0.731959 0.681348 -7.56448e-16 0.840593 0.541667 -6.01371e-16 0.840593 0.541667 -6.01371e-16 1 -0 -0 0.989778 0.142617 -1.58336e-16 0.959321 0.282318 -3.13436e-16 0.909252 0.416247 -4.62127e-16 1 -0 -0 1 -0 -0 0.98393 -0.178557 1.98238e-16 0.936235 -0.351375 3.90104e-16 0.858449 -0.512899 5.69433e-16 0.753071 -0.657939 7.30459e-16 0.62349 -0.781831 8.68007e-16 0.473869 -0.880596 9.77657e-16 0.309017 -0.951057 1.05588e-15 0.134233 -0.99095 1.10018e-15 -0.0448648 -0.998993 1.10911e-15 -0.222521 -0.974928 1.08239e-15 -0.393025 -0.919528 1.02088e-15 -0.550897 -0.834573 9.26562e-16 -0.691063 -0.722795 8.02464e-16 -0.809017 -0.587785 6.52573e-16 -0.900969 -0.433884 4.81708e-16 -0.963963 -0.266037 2.9536e-16 -0.995974 -0.0896393 9.95196e-17 -0.995974 0.0896393 -9.95196e-17 -0.963963 0.266037 -2.9536e-16 -0.900969 0.433884 -4.81708e-16 -0.809017 0.587785 -6.52573e-16 -0.691063 0.722795 -8.02464e-16 -0.550897 0.834573 -9.26562e-16 -0.393025 0.919528 -1.02088e-15 -0.222521 0.974928 -1.08239e-15 -0.0448648 0.998993 -1.10911e-15 0.134233 0.99095 -1.10018e-15 0.309017 0.951057 -1.05588e-15 0.473869 0.880596 -9.77657e-16 0.62349 0.781831 -8.68007e-16 0.753071 0.657939 -7.30459e-16 0.858449 0.512899 -5.69433e-16 0.936235 0.351375 -3.90104e-16 0.98393 0.178557 -1.98238e-16 1 -0 -0 0.909252 -0.416247 4.62127e-16 0.959321 -0.282318 3.13436e-16 0.989778 -0.142617 1.58336e-16 -0 -1 1.11022e-15 -0 -1 1.11022e-15 -0 -1 1.11022e-15 -0 -1 1.11022e-15 0.691661 -0.722222 8.01828e-16 0.822356 -0.568974 6.31688e-16 0.91969 -0.392644 4.35923e-16 0.979717 -0.200387 2.22474e-16 1 -1.13311e-15 1.258e-30 0.979717 0.200387 -2.22474e-16 0.91969 0.392644 -4.35923e-16 0.822356 0.568974 -6.31688e-16 0.691661 0.722222 -8.01828e-16 0.691661 -0.722222 8.01828e-16 0.822356 -0.568974 6.31688e-16 0.91969 -0.392644 4.35923e-16 0.979717 -0.200387 2.22474e-16 1 -1.13311e-15 1.258e-30 0.979717 0.200387 -2.22474e-16 0.91969 0.392644 -4.35923e-16 0.822356 0.568974 -6.31688e-16 0.691661 0.722222 -8.01828e-16 -9.4387e-17 1 -1.11022e-15 -9.4387e-17 1 -1.11022e-15 -9.4387e-17 1 -1.11022e-15 -9.4387e-17 1 -1.11022e-15 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 2.47768e-32 -9.81286e-16 -1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 1 -0 -0 0.970942 -0.239316 2.65694e-16 0.885456 -0.464723 5.15946e-16 0.748511 -0.663123 7.36214e-16 0.568065 -0.822984 9.13696e-16 0.354605 -0.935016 1.03808e-15 0.120537 -0.992709 1.10213e-15 -0.120537 -0.992709 1.10213e-15 -0.354605 -0.935016 1.03808e-15 -0.568065 -0.822984 9.13696e-16 -0.748511 -0.663123 7.36214e-16 -0.885456 -0.464723 5.15946e-16 -0.970942 -0.239316 2.65694e-16 -1 -1.01064e-15 1.12204e-30 -0.970942 0.239316 -2.65694e-16 -0.885456 0.464723 -5.15946e-16 -0.748511 0.663123 -7.36214e-16 -0.568065 0.822984 -9.13696e-16 -0.354605 0.935016 -1.03808e-15 -0.120537 0.992709 -1.10213e-15 0.120537 0.992709 -1.10213e-15 0.354605 0.935016 -1.03808e-15 0.568065 0.822984 -9.13696e-16 0.748511 0.663123 -7.36214e-16 0.885456 0.464723 -5.15946e-16 0.970942 0.239316 -2.65694e-16 1 -0 -0 1 -0 -0 1 -0 -0 0.970942 -0.239316 2.65694e-16 0.885456 -0.464723 5.15946e-16 0.748511 -0.663123 7.36214e-16 0.568065 -0.822984 9.13696e-16 0.354605 -0.935016 1.03808e-15 0.120537 -0.992709 1.10213e-15 -0.120537 -0.992709 1.10213e-15 -0.354605 -0.935016 1.03808e-15 -0.568065 -0.822984 9.13696e-16 -0.748511 -0.663123 7.36214e-16 -0.885456 -0.464723 5.15946e-16 -0.970942 -0.239316 2.65694e-16 -1 -1.01064e-15 1.12204e-30 -0.970942 0.239316 -2.65694e-16 -0.885456 0.464723 -5.15946e-16 -0.748511 0.663123 -7.36214e-16 -0.568065 0.822984 -9.13696e-16 -0.354605 0.935016 -1.03808e-15 -0.120537 0.992709 -1.10213e-15 0.120537 0.992709 -1.10213e-15 0.354605 0.935016 -1.03808e-15 0.568065 0.822984 -9.13696e-16 0.748511 0.663123 -7.36214e-16 0.885456 0.464723 -5.15946e-16 0.970942 0.239316 -2.65694e-16 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 1 -0 -0 0.970942 -0.239316 2.65694e-16 0.885456 -0.464723 5.15946e-16 0.748511 -0.663123 7.36214e-16 0.568065 -0.822984 9.13696e-16 0.354605 -0.935016 1.03808e-15 0.120537 -0.992709 1.10213e-15 -0.120537 -0.992709 1.10213e-15 -0.354605 -0.935016 1.03808e-15 -0.568065 -0.822984 9.13696e-16 -0.748511 -0.663123 7.36214e-16 -0.885456 -0.464723 5.15946e-16 -0.970942 -0.239316 2.65694e-16 -1 -1.01064e-15 1.12204e-30 -0.970942 0.239316 -2.65694e-16 -0.885456 0.464723 -5.15946e-16 -0.748511 0.663123 -7.36214e-16 -0.568065 0.822984 -9.13696e-16 -0.354605 0.935016 -1.03808e-15 -0.120537 0.992709 -1.10213e-15 0.120537 0.992709 -1.10213e-15 0.354605 0.935016 -1.03808e-15 0.568065 0.822984 -9.13696e-16 0.748511 0.663123 -7.36214e-16 0.885456 0.464723 -5.15946e-16 0.970942 0.239316 -2.65694e-16 1 -0 -0 1 -0 -0 1 -0 -0 0.970942 -0.239316 2.65694e-16 0.885456 -0.464723 5.15946e-16 0.748511 -0.663123 7.36214e-16 0.568065 -0.822984 9.13696e-16 0.354605 -0.935016 1.03808e-15 0.120537 -0.992709 1.10213e-15 -0.120537 -0.992709 1.10213e-15 -0.354605 -0.935016 1.03808e-15 -0.568065 -0.822984 9.13696e-16 -0.748511 -0.663123 7.36214e-16 -0.885456 -0.464723 5.15946e-16 -0.970942 -0.239316 2.65694e-16 -1 -1.01064e-15 1.12204e-30 -0.970942 0.239316 -2.65694e-16 -0.885456 0.464723 -5.15946e-16 -0.748511 0.663123 -7.36214e-16 -0.568065 0.822984 -9.13696e-16 -0.354605 0.935016 -1.03808e-15 -0.120537 0.992709 -1.10213e-15 0.120537 0.992709 -1.10213e-15 0.354605 0.935016 -1.03808e-15 0.568065 0.822984 -9.13696e-16 0.748511 0.663123 -7.36214e-16 0.885456 0.464723 -5.15946e-16 0.970942 0.239316 -2.65694e-16 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 -0 1.11022e-15 1 ]
"bool generatetangents" ["false"]
"string name" ["Lux_Pocket"]
AttributeEnd # ""
# End of FreeCAD objects
AttributeBegin # "groundplane"
Transform [1.000000000000000 0.000000000000000 0.000000000000000 0.000000000000000 0.000000000000000 1.000000000000000 0.000000000000000 0.000000000000000 0.000000000000000 0.000000000000000 1.000000000000000 0.000000000000000 0.000000000000000 0.000000000000000 0.000000000000000 1.000000000000000]
Shape "mesh"
"integer triindices" [0 1 2 0 2 3]
"point P" [-1000.000000000000000 -1000.000000000000000 0.000000000000000 1000.000000000000000 -1000.000000000000000 0.000000000000000 1000.000000000000000 1000.000000000000000 0.000000000000000 -1000.000000000000000 1000.000000000000000 0.000000000000000]
"normal N" [0.000000000000000 0.000000000000000 1.000000000000000 0.000000000000000 0.000000000000000 1.000000000000000 0.000000000000000 0.000000000000000 1.000000000000000 0.000000000000000 0.000000000000000 1.000000000000000]
"string name" ["groundplane"]
AttributeEnd # ""
# Volume File
AttributeBegin # "Lamp"
LightGroup "default"
LightSource "sunsky2"
"float gain" [1.000000000000000]
"float importance" [1.000000000000000]
"integer nsamples" [1]
"float turbidity" [2.200000047683716]
"vector sundir" [0.028625251725316 -0.011037390679121 0.040162373334169]
AttributeEnd # ""
WorldEnd
3d_render_user
the nvidia driver version.
This is the latest version I can install. there's a 4xx driver but I can't install because of DCH, something like that.
NVIDIA System Information report created on: 06/12/2021 23:15:45
System name: 3D_FreeCad_Render
[Display]
Operating System: Windows 10 Pro, 64-bit
DirectX version: 12.0
GPU processor: Quadro K2000M
Driver version: 392.65
Direct3D API version: 12
Direct3D feature level: 11_0
CUDA Cores: 384
Core clock: 745 MHz
Memory data rate: 1800 MHz
Memory interface: 128-bit
Memory bandwidth: 28.80 GB/s
Total available graphics memory: 5927 MB
Dedicated video memory: 2048 MB DDR3
System video memory: 0 MB
Shared system memory: 3879 MB
Video BIOS version: 80.07.31.00.18
IRQ: Not used
Bus: PCI Express x16 Gen2
Device Id: 10DE 0FFB 21F517AA
Part Number: 1303 0020
[Components]
nvui.dll 8.17.13.9265 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.13.9265 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.13.9265 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.13.9265 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.13.9265 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.940.0 NVIDIA Control Panel
nvCplUI.exe 8.1.940.0 NVIDIA Control Panel
nvWSSR.dll 23.21.13.9265 NVIDIA Workstation Server
nvWSS.dll 23.21.13.9265 NVIDIA Workstation Server
nvViTvSR.dll 23.21.13.9265 NVIDIA Video Server
nvViTvS.dll 23.21.13.9265 NVIDIA Video Server
NVSTVIEW.EXE 7.17.13.9265 NVIDIA 3D Vision Photo Viewer
NVSTTEST.EXE 7.17.13.9265 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.13.9265 NVIDIA 3D Vision Module
nvDispSR.dll 23.21.13.9265 NVIDIA Display Server
NVMCTRAY.DLL 23.21.13.9265 NVIDIA Media Center Library
nvDispS.dll 23.21.13.9265 NVIDIA Display Server
nvDevToolS.dll 23.21.13.9265 NVIDIA 3D Settings Server
NVCUDA.DLL 23.21.13.9265 NVIDIA CUDA 9.1.84 driver
nvGameSR.dll 23.21.13.9265 NVIDIA 3D Settings Server
nvGameS.dll 23.21.13.9265 NVIDIA 3D Settings Server
3d_render_user wrote: Sat Jun 12, 2021 8:54 pm Is there a way to force it to run in CPU mode?
If you pass the following command line option, you will force the use of CPU only:
-D renderengine.type PATHCPU
Some more example: http://forums.luxcorerender.org/viewtop ... =854#p8984
3d_render_user
Dade wrote: Sat Jun 12, 2021 9:46 pm
Same problem.
Is there way to edit the lxs file and force it to use CPU?
3d_render_user wrote: Sat Jun 12, 2021 10:38 pm Same problem.
Your GPU is too old and it doesn't support the CUDA code used, not only for the rendering, but also for the image pipeline. You have also to disable the use of the GPU for the image pipeline with another additional argument:
-D film.opencl.enable 0
