Pearl material
josephmcs
Pearl material
Post by josephmcs » Tue Jun 01, 2021 8:09 pm
Has anyone had success making pearlescent materials/pearls with Luxcorerender?
It seems like the engine would be very naturally suited to this considering the thin film interference feature.
However, I can't find much documentation.
I found this very old breakdown for Luxrender, but the interface/values have changed greatly since then.
https://www.loramel.net/2009/03/materia ... own-pearl/
Help and ideas are appreciated!
Re: Pearl material
Post by Dade » Tue Jun 01, 2021 9:13 pm
Actually, for what I can see, every single material and parameter motioned in the above link is still available.
josephmcs
Re: Pearl material
Post by josephmcs » Wed Jun 02, 2021 2:04 am
Thanks. One thing that is confusing me is what the "exp" values are.
For example, the roughness on the glossy material in the old breakdown is set at "exp = 50" whereas in Luxcorerender the roughness is on a scale of 0-1.
Sorry if this is rudimentary and any help is much appreciated.
Re: Pearl material
Post by B.Y.O.B. » Wed Jun 02, 2021 8:43 am
See the section "Roughness" here for the conversion formula: https://wiki.luxcorerender.org/LuxCoreR ... sy_Coating
josephmcs
Re: Pearl material
Post by josephmcs » Wed Jun 02, 2021 4:28 pm
Thanks so much for your help.
For anybody interested, I converted the old values into a node tree setup. See attached w/ a sample render, too.
Any input is very welcome of course.
Re: Pearl material
Post by kintuX » Wed Jun 02, 2021 6:13 pm
Nice.
And a different go for pearlescent material.
josephmcs
Re: Pearl material
Post by josephmcs » Thu Jun 03, 2021 7:20 pm
Cool! Thank you.
I put the two of them side by side for a little test if anybody is curious. Mine is on left, yours on right. Nice to see the different approaches together. I think my version of yours could use some tweaking on the noise size, but I like it.
Re: Pearl material
Post by kintuX » Sun Jun 06, 2021 9:02 pm
True, depending on the size of geo, noise and volume must be tweaked.
For study I use MaterialX shaderball (.../resources/geometry/) @ 20cm in diameter.
