Dispersion & Rough (Mix) and Noise
chiraagm
Post by chiraagm » Wed May 19, 2021 5:57 pm
I am trying to create realistic diamond jewelry renders and went through a few engines (Cycles, Octane and LuxCore)
While cycles is an amazing engine not the best for diamonds (especially since it lacks dispersion).
Octane was my winner until I came across LuxCore. Octane has this feature to have roughness and dispersion both enabled at the same time in Specular materials (like glass/diamonds). Just like anything else in the rendering world, nothing is perfect, so just like there should be no fully white or fully black, in the same manner there needs to be a very slight roughness (somewhere around 0.001 to 0.002) to create a realistic diamond.
To achieve this I am using two Glass materials with the same IOR, the only thing different is one has dispersion, and the other has Rough enabled (0.0015). I am currently mixing these materials through a mix node with 15% (rough glass) -85% (dispersion glass). Using just Dispersion glass, I am getting relatively noise free renders after about 500 samples (2880 x 2400), but the image only looks realistic with the mix node (some amount of roughness), in which case I am getting a fair amount of noise.
Is there a better way to achieve roughness and dispersion, so as to not create so much "noise"
I understand that increasing the sample count seems the easy thing to do, but that would pretty much double/triple my render times
Re: Dispersion & Rough (Mix) and Noise
Post by Dade » Wed May 19, 2021 8:56 pm
You could try to create some roughness in pure glass trough (very light, high resolution image or procedural) bump mapping :idea:
chiraagm
Post by chiraagm » Thu May 20, 2021 7:05 am
Thanks Dade
Will try it out
