Persistent Cache not loaded
Hi !
DOn't know if someone else get into the same issue but I'm running an animation with persistent PGI/ENV cache and i get huge flickering due to
the fact that cached files are sometime not loaded by Luxcore. here is the result :
Animation_Test
Poo_1l.mp4
(413.9 KiB) Downloaded 140 times
Here when cache isn't auto loaded
Here when i manually load cache file
and it is what happen during the animation rendering cache file are randomlly loaded and unloaded.
Making the final result to switch between bright and dark look constantlly.
Re: Persistent Cache not loaded
Here you can see how it look like on frame folder. Darker frame randomlly sisde by side with brighter frame :
Sharlybg wrote: Wed May 05, 2021 9:46 pm flickering due to the fact that cached files are sometime not loaded by Luxcore.
What does it mean ? Do you get an error ?
Dade wrote: Wed May 05, 2021 10:53 pm
No error in the error log panel. But you can see that it lead to a strong unstable light intensity between frames in both video and images i have posted.
I have been enable to reproduce the issue i think: just precompute your cache and save somewhere and disable overwrite after. then press CTR+F12 to launch animation (make sure to choose a folder for frames ).
issue.7z
(1.03 MiB) Downloaded 120 times
Sharlybg wrote: Wed May 05, 2021 11:17 pm I have been enable to reproduce the issue i think: just precompute your cache and save somewhere and disable overwrite after. then press CTR+F12 to launch animation (make sure to choose a folder for frames ).
By looking at the settings, you have enabled periodic updates: you must disable it or the caustic cache will be loaded and than discarded and replaced after 8 samples. Indeed, it is not what you want.
Dez!
Post by Dez! »
Water is so cool that I want to dive into it and swim under water the entire pool
Dade wrote: Thu May 06, 2021 10:24 am
I Forget to disable that sorry in this file (wasn't enable in original file). But even if i disable it in the simplified scene i continue to have same error.
Dez! wrote: Thu May 06, 2021 10:32 am Water is so cool that I want to dive into it and swim under water the entire pool
Thanks Dez ;) ! i found a way to animate water with kind of SDS caustics within Luxcore current limitation. And i hope the bug get fixed to launch animation final frames.
I have simplified the cache by using only caustic cache no more envi or indirect cache.
And it is still unstable with a persistent cache.
Is it a bug i really want to complete this project.
This Blinking is gonna run me Crazy :| . No matter what i do it is breaking the cache is persistent so why it is changing without periodic update ?
POOL0001-0500.mp4
(710.28 KiB) Downloaded 182 times
