So what? You just don't want to see the pictures I attach. Look, the objects are completely white (it's the "Transmission color", I've tested it) . This is not how they should be.Dade wrote: ↑Thu May 17, 2018 11:32 pm
You are confusing object transparency (or opacity if you prefer) with object surface+volume. Transparency makes all object (surface+volume) transparent, like with alpha channel. In your case must be set to 0, it is not what you are looking for.
The object material describes the surface (i.e. the "skin") of an object while volume describes the interior.
And now for what I expected to see: Not some transparency or whatever.
But with a slightly different angle I see this: Somehow this doesn't happen to objects in example by B.Y.O.B.
