Homogeneous volume absorption depth
wasd
Post by wasd » Thu May 17, 2018 2:44 pm
Blender 2.79b
LuxCore 2.1 alpha0
CPU Path + Metropolis (also BiDir + Metropolis and Path/BiDir + Sobol)
Glossy Translucent Material with interior homogeneous volume
I can't see any difference, though every ball have different absorption depth
From left to right: 0.01 mm, 0.1 mm, 1 mm, 1 cm, 1 m, 10 m, 100 m
machine-le-grass-test-eg.blend
(5.07 MiB) Downloaded 91 times
CPU Bidir + Metropolis | Log Power | Core i5-4570
Re: Homogeneous volume absorption depth
Post by B.Y.O.B. » Thu May 17, 2018 3:03 pm
The transmission color of the glossy translucent mat is black, so the volume does not make any difference because no light is transmitted.
wasd
Post by wasd » Thu May 17, 2018 3:52 pm
Do you have an example scene, which shows the difference in absorption depth? I still cannot figure out how absorption depth affects the material.
This scene has transmission color 7F7F7F at all balls.
Post by kintuX » Thu May 17, 2018 4:40 pm
Yes, looks like it's something wrong in Blender.
PS.
It works fine in Material Preview, but not in Render Preview nor in Final render.
Post by B.Y.O.B. » Thu May 17, 2018 5:40 pm
The absorption depth is the distance after which a white light ray (1, 1, 1) has the color that is specified as absorption color.
You can see the effect best with the null material.
wasd
Post by wasd » Thu May 17, 2018 6:04 pm
What about an example?
wasd
Post by wasd » Thu May 17, 2018 6:47 pm
OK. I get it. Volumes just don't really work with anything but Null material.
machine-le-grass-test-ej.blend
(4.23 MiB) Downloaded 89 times
Post by B.Y.O.B. » Thu May 17, 2018 7:56 pm
Volumes are independent from materials.
The material describes the surface, the volume describes everything inside or outside of the surface.
You might see something else than you expect because the material reflects too much light and transmits too little?
From left to right:
- Null
- Matte Translucent
- Glossy Translucent
- Glass
- Rough Glass
Hope this helps.
volume_depth_example.blend
(883.66 KiB) Downloaded 97 times
wasd
Post by wasd » Thu May 17, 2018 8:46 pm
Maybe.
Post by Dade » Thu May 17, 2018 11:32 pm
Maybe.
You are confusing object transparency (or opacity if you prefer) with object surface+volume. Transparency makes all object (surface+volume) transparent, like with alpha channel. In your case must be set to 0, it is not what you are looking for.
The object material describes the surface (i.e. the "skin") of an object while volume describes the interior.
