Hello Everyone,
Using Blender 2.92 & the LuxCore 2.5
I have downloaded the demo scene "Danish Mood" and rendered. It does render, but I get the following errors for a couple of items:
Final render subdivision level (2) smaller than viewport subdivision level (3)
Question - Where do I set the "Final render subdivision level"? I believe I have expanded everything in the render properties and output properties panel in Blender.
Thanks in advance
Re: render subdivision level
It's about the settings in the subdivision surface modifier. You can select the relevant object with the button to the right of the warning in the error log.
B.Y.O.B - Thank you sir - I did not think to look at the modifier.
