LuxCore 2.5 Release Installation Error on Linux
johannes.wilde
Post by johannes.wilde »
System:
PopOS 20.04
NVidia driver 460.67
Hi!
While i can use LuxCore2.5rc on my system, i can't install LuxCore 2.5 Release.
By the way i as well tried it in Vanilla Blender 2.92, it's not related to E-Cycles build.
I get the following message:
File "/home/XXX/Downloads/E_Cycles_2.92_2021_release_v20210224_lin_rtx/2.92/scripts/modules/addon_utils.py", line 351, in enable
mod = __import__(module_name)
File "/home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/__init__.py", line 63, in <module>
Exception:
Could not import pyluxcore.
ImportError: /home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin/libOpenImageDenoise.so.0: undefined symbol: _ZN3tbb10interface78internal15task_arena_base24internal_max_concurrencyEPKNS0_10task_arenaE
Re: LuxCore 2.5 Release Installation Error on Linux
It sounds like your libOpenImageDenoise is too old or too new. Maybe you tried to copy/paste the addon over an existing installation?
Try to remove the old addon completely, then install v2.5.
johannes.wilde
Thanks for your reply!
I just installed it over an existing version of LuxCore.
Now deleted the folder in ./config/blender/2.92/scrips/addons/BlendLuxCore restarted the Computer an reinstalled BlendLuxCore again, but still I get the error message. Are there more files/folders to remove?
It looks like a problem with Intel TBB (used by Intel denoiser). Try to run:
ldd  /home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin/libOpenImageDenoise.so.0
and also for TTB library .so too. Post here the output, you may lack the "x" execution bit or have some other similar problem.
johannes.wilde
Here comes the output:
linux-vdso.so.1 (0x00007ffd52aa8000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fb05ba14000)
libtbb.so.2 => /home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin/libtbb.so.2 (0x00007fb05b7b1000)
libtbbmalloc.so.2 => /home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin/libtbbmalloc.so.2 (0x00007fb05b559000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fb05b553000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fb05b372000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb05b221000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fb05b206000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb05b01c000)
/lib64/ld-linux-x86-64.so.2 (0x00007fb05e80b000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fb05b011000)
johannes.wilde wrote: Tue Apr 13, 2021 5:04 am Here comes the output:
Try also to run the following commands:
david@Desktop-3900x:~/.config/blender/2.92/scripts/addons/BlendLuxCore/bin$ cd /home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin
david@Desktop-3900x:~/.config/blender/2.92/scripts/addons/BlendLuxCore/bin$ ldd libtbb.so.2
	linux-vdso.so.1 (0x00007fffd7bf9000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f2833173000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f2833168000)
	libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f2832f87000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f2832e38000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f2832e1d000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f2832dfa000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f2832c06000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f28333f8000)
david@Desktop-3900x:~/.config/blender/2.92/scripts/addons/BlendLuxCore/bin$ ldd libtbbmalloc.so.2
	linux-vdso.so.1 (0x00007ffdbcf70000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f375054e000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f3750543000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f37503f4000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f37503d9000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f37503b6000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f37501c4000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f37507c8000)
david@Desktop-3900x:~/.config/blender/2.92/scripts/addons/BlendLuxCore/bin$ md5sum libOpenImageDenoise.so.0 libtbb.so.2 libtbbmalloc.so.2
0d1cc787de55664f59ca954fcaabbae2  libOpenImageDenoise.so.0
999ecd6cca7410a82083cabf597a3a09  libtbb.so.2
6a5c66a88bff8047638c52a5bc7da184  libtbbmalloc.so.2
Check if the checksum of my files matches your.
johannes.wilde
ldd libtbb.so.2
linux-vdso.so.1 (0x00007ffcd7365000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f2fc5c8c000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f2fc5c81000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f2fc5aa0000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f2fc5951000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f2fc5936000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f2fc5914000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f2fc5728000)
/lib64/ld-linux-x86-64.so.2 (0x00007f2fc5f18000)
This is what I get. Looks the same to me.
johannes.wilde
I installed the latest BlendLuxCore build today and get a slighly different error message:
File "/home/XXX/Downloads/blender-2.92.0-linux64/2.92/scripts/modules/addon_utils.py", line 351, in enable
Exception:
ImportError: libOpenImageDenoise.so.1: cannot open shared object file: No such file or directory
I lookend in
/home/XXX/.config/blender/scripts/addons/BlendLuxCore/bin
and found a file called oidnDenoise but no libOpenImageDenoise.so.1
acasta69
Post by acasta69 »
johannes.wilde wrote: Wed Apr 21, 2021 2:00 pm I lookend in
This should now be fixed, please get the very latest BlendLuxCore.
johannes.wilde
Thank you!
That works now.
