LinuxCompile Environment buildscript asks for unknown libpython3.6.a
Posted: Sun May 13, 2018 6:51 pm
by joc
HI!
Trying to compile LuxCore (for running it on my SSE3/SSE2 machine) using LinuxCompile Environment I followed the README
with
./build-64-sse2 LuxCore
download of dependencies worked fine, target tree was build and then
ran into:
* Done creating target tree
 * Checking libstdc++
 * Library symlink is missing, attempting to figure out the proper location
 !!! Unable to find libstdc++.a at known locations.
 !!! You have to find the library manually and symlink
 !!! it to the following path:
 !!! /home/joc/Programme/LuxCore/LinuxCompile/target-64-sse2/lib/libstdc++.a
found, linked, no problem, but next launch asks for
* Done checking distfiles
 * Checking target tree
 * Target tree exists
 * Done checking libstdc++
 * Checking python
 !!! Unable to find libpython3.6.a or libpython3.6m.a at known
 !!! locations. You have to find the library manually and
 !!! symlink it to the following path:
 !!! /home/joc/Programme/LuxCore/LinuxCompile/target-64-sse2/lib/libpython3.6.a
I could not find yet a package or repo containing this library...
Re: LinuxCompile Environment buildscript asks for unknown libpython3.6.a
Posted: Sun May 13, 2018 8:43 pm
joc wrote: Sun May 13, 2018 6:51 pm I could not find yet a package or repo containing this library...
What Linux distribution are you using ?
You can use any python 3.x version. It usual part of something like libpython3.5-stdlib: https://packages.ubuntu.com/search?keyw ... bpython3.5
Posted: Mon May 14, 2018 7:00 pm
by joc
Dade wrote: Sun May 13, 2018 8:43 pm
Sorry, somehow I broke my system. Opensuse Tumbleweed. Python 3.6 package is without static library indeed. I've build one from source now, made a symlink to the build and compiling went on to:
common.mkdir bin.v2/libs/python/build/gcc-7/release/link-static/threading-multi
gcc.compile.c++ bin.v2/libs/python/build/gcc-7/release/link-static/threading-multi/numeric.o
In file included from ./boost/python/detail/prefix.hpp:13:0,
                 from ./boost/python/numeric.hpp:8,
                 from libs/python/src/numeric.cpp:6:
./boost/python/detail/wrap_python.hpp:50:11: fatal error: pyconfig.h: Datei oder Verzeichnis nicht gefunden
 # include <pyconfig.h>
compilation terminated.
    "g++"  -ftemplate-depth-128 -O3 -finline-functions -Wno-inline -Wall -pthread -w -mtune=generic -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -w -mtune=generic -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -DBOOST_ALL_NO_LIB=1 -DBOOST_PYTHON_SOURCE -DBOOST_PYTHON_STATIC_LIB -DNDEBUG  -I"." -I"/usr/include/python3.6" -c -o "bin.v2/libs/python/build/gcc-7/release/link-static/threading-multi/numeric.o" "libs/python/src/numeric.cpp"
...failed gcc.compile.c++ bin.v2/libs/python/build/gcc-7/release/link-static/threading-multi/numeric.o...
gcc.compile.c++ bin.v2/libs/locale/build/gcc-7/release/link-static/threading-multi/std/std_backend.o
gcc.compile.c++ bin.v2/libs/locale/build/gcc-7/release/link-static/threading-multi/util/gregorian.o
gcc.compile.c++ bin.v2/libs/locale/build/gcc-7/release/link-static/threading-multi/posix/numeric.o
gcc.compile.c++ bin.v2/libs/locale/build/gcc-7/release/link-static/threading-multi/std/numeric.o
...failed updating 1 target...
...updated 3156 targets...
 !!! Boost compilation failed
Will continue...
:idea: Edit:
So, although both of my python installs (2.7 and 3.6m) contain a pyconfig.h
export CPLUS_INCLUDE_PATH="$CPLUS_INCLUDE_PATH:/usr/include/python3.6m/"
solved this
Next hurdle ist IlmBase
test_prefix = /home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2
checking for pkg-config... /usr/bin/pkg-config
using ilmbase-prefix to set ILMBASE_CXXFLAGS, ILMBASE_LDFLAGS and ILMBASE_LIBS:
    ILMBASE_CXXFLAGS =  -I/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/include/OpenEXR
    ILMBASE_LDFLAGS = -L/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/lib -L/usr/lib64 -L/usr/local/lib
    ILMBASE_LIBS = -lImath -lHalf -lIex -lIlmThread -lpthread
checking for IlmBase... no
*** Could not run the IlmBase test program, checking why...
*** The IlmBase test program could be compiled, but could not be dynamically.
*** or statically linked.
*** Make sure the LDFLAGS points to the location of the IlmBase library.
*** (e.g. -L/usr/local/lib).
*** If the run-time linker is not finding IlmBase, you'll need to set your
*** LD_LIBRARY_PATH environment variable, or edit /etc/ld.so.conf to point
*** to the installed location  Also, make sure you have run ldconfig if that
*** is required on your system.
*** Flags used by the test:
***     cflags: -w -mtune=generic -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC  -I/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/include/OpenEXR
***     ldflags: -L/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/lib -static-libgcc -static-libstdc++ -L/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/lib -L/usr/lib64 -L/usr/local/lib
*** You can also run configure with --disable-ilmbasetest to skip this test.
configure: error: Could not compile IlmBase test program.
 !!! openexr configuration failed
