Dade wrote: ↑Tue Feb 09, 2021 11:30 am
The latest LuxCore uses C++ code for rendering, by default, with the CPU (i.e. no need to use/have an OpenCL CPU device). To disable the CPU usage, you have to set the number of CPU threads to 0 by setting "native.threads.count" to 0.
I notice that all your values are quoted. I'm not sure if it makes a difference, but I think if the value is a pure int or float, then it should not be quoted?
Martini wrote: ↑Wed Feb 10, 2021 10:02 am
I think you are missing the opencl. prefix.
Yes, I was wrong "native.threads.count" is for PATHCPU, PATHOCL requires "opencl.native.threads.count".
Yea, that did it. Now the GPU are stressed on their own.
I did 3x 12hrs tests and it failed twice. Next thing I am going to try is a different stresstest. Do you have one to reccomend? I need to stress all GPUs at the same time and do not have a display attached to all of them.
I already tried Furmark but as far as I know I would need for each GPU a display.
Wumme wrote: ↑Fri Feb 12, 2021 7:15 am
May be AMD ProRender
