Network render
Re: Network render
Post by Dade » Mon May 07, 2018 9:54 am
Dade wrote:
Mon May 07, 2018 9:39 am
Going to try Windows.
It seems to be a Windows-only problem :roll: Going to check what is going on.
Re: Network render
Post by Dade » Tue May 08, 2018 10:21 am
The only problem on Windows seems a division by zero on an elapsed time due to the very low timer resolution. However I was getting an explicit error, not a freeze like you. Once I fixed the division by zero, it works fine here:
Can you try if this (https://drive.google.com/file/d/1bf662u ... sp=sharing) pyluxcoretool.exe is working for you ? I have the feeling that the division by zero isn't your problem.
Re: Network render
Post by Sharlybg » Wed May 09, 2018 10:06 am
As you expect it doesn't change SiR Sherlock holmes ;) !
Kajny
Re: Network render
Post by Kajny » Fri Jan 11, 2019 7:30 am
I have the same problem like Sharlybg.
Re: Network render
Post by Dade » Fri Jan 11, 2019 3:24 pm
I reopened the issue: https://github.com/LuxCoreRender/LuxCor ... -453551927
I'm working on the couple of things at the moment and I can not look into this problem right now. I will when I have finished.
