Hi and Blender Normal Map
arvinmoses
Post by arvinmoses » Wed Jan 10, 2018 4:21 am
Hi guys! Glad to be testing LuxcoreRender 2.
Testing it currently with blender and having issues with running normal map. Doc says:
Load normal via imagemap node
Turn on normal option
Plug into Bump slot
I couldn't find the normal option anywhere, and so I tried plugging it directly to the bump slot, but that did not turn out correctly.
I also wanted to ask if there is a discplacement option. Thanks guys and looking forward to working with LCR more in the future.
Re: Hi and Blender Normal Map
Post by B.Y.O.B. » Wed Jan 10, 2018 8:25 am
Normal mapping is not supported by the addon yet.
The wiki is misleading in that regard, sorry.
Not yet in LuxCore.
You'll have to use Blender's displacement modifier.
Piita
Supporting Users
Post by Piita » Wed Jan 10, 2018 7:25 pm
The wiki documentation is still very new and will not fully reflect the current state of the exporter. This will change in time though. Sorry for the confusion.
arvinmoses
Post by arvinmoses » Sat Jan 13, 2018 10:42 pm
Thanks a ton for the response guys. Sorry it took me some time to response. Was a bit busy with catch up at work.
Most of my test is based on normal/displacement. I may not be a ton of help til it's implemented, but I'll keep messing around with it. I really love the results.
Post by B.Y.O.B. » Sun Jan 14, 2018 11:50 am
Normal mapping will be in the next alpha release: viewtopic.php?f=5&p=530#p525
