Clamp Output
david57
Clamp Output
Post by david57 »
Looks like the Set Suggested Value for Clamp Output is not working correctly but not sure.
Maybe im wrong.
When the Clamp Output is checked or enabled it causes the scene to crash.
Goodnight...
Re: Clamp Output
david57 wrote: Mon Apr 23, 2018 5:47 am Looks like the Set Suggested Value for Clamp Output is not working correctly but not sure.
Maybe im wrong.
Goodnight...
I need specific details about the crash: how to reproduce problem and/or a test scene causing the crash.
david57
Re: Clamp Output
Post by david57 »
Ok, Im using a test scene from wahn.
It renders beautifully without a crash but when I use the suggested value for the
clamp output it crashes in about 4 minutes.
Re: Clamp Output
Post by Racleborg »
10 mins with clamp ON. No problem here with old i7 920 and 12gb ram (attached)
david57
Re: Clamp Output
Post by david57 »
It might require more render time or samples.
david57
Re: Clamp Output
Post by david57 »
With this scene, I disabled the Clamp Output and rendered it for 8 hours without a crash.
Re: Clamp Output
I will check this problem soon after I finished fixing kintuX's problematic scene.
Re: Clamp Output
Post by Racleborg »
Re tested the Breakfast_Lux Test Scene with Bi Dir and Clamp On and it crashed after about 12 mins.
Re: Clamp Output
david57 wrote: Mon Apr 23, 2018 5:18 pm Ok, Im using a test scene from wahn.
I was able to reproduce the problem here and it should be now fixed. It was an out of bound memory access in variance clamping when using metropolis sampler due to yet-another-numerical-precision problem.
You can download a pyluxcore.pyd file with the fix from https://drive.google.com/file/d/1D8tenO ... sp=sharing
david57
Re: Clamp Output
Post by david57 »
Thank you.
