weighted normal modifier not working
zooropa
Post by zooropa » Sat Sep 12, 2020 3:04 pm
Hi. I am using a weighted normal modifier in my mesh in order to avoid the broken reflections of the mesh. I can see it works in the viewport, but not in the render. I am using lux 2.5 If this is not supported I will proceed to model the mesh only with quads and subdivision modifier. I was trying to avoid complex topology since its just a flat plane with thickness and bevel edges.
Thank you
Re: weighted normal modifier not working
Post by Sharlybg » Sat Sep 12, 2020 3:22 pm
I don't know about weighted normal modifier but sharp edge modifier should do the trick.
PetrT
Post by PetrT » Sat Sep 12, 2020 3:32 pm
maybe edge split can help
zooropa
Post by zooropa » Sat Sep 12, 2020 3:33 pm
There is no sharp edge modifier
zooropa
Post by zooropa » Sat Sep 12, 2020 4:04 pm
I think its cause luxcore does not take in count that modifier maybe
Post by Sharlybg » Sat Sep 12, 2020 4:09 pm
Talking about this one.
zooropa
Post by zooropa » Sat Sep 12, 2020 4:28 pm
Not working, I happily share my file if you like to
Post by B.Y.O.B. » Sat Sep 12, 2020 5:45 pm
What Blender version are you using? Custom normals are not yet supported in Blender 2.90.
zooropa
Post by zooropa » Sat Sep 12, 2020 6:44 pm
I am using 2.9 so actually this artifact will be visible also in cycles...
zooropa
Post by zooropa » Sun Sep 13, 2020 8:09 am
Do you mean luxcore and blender 2.9 ? Cause I tried and works in cycles.
