GPU viewport performance
Posted: Thu Sep 03, 2020 12:43 pm
After some further testing on this topic here :
viewtopic.php?f=4&t=2521 . I think i've finger on something.
The effort is about making GPU viewport responssivness faster.
For the experiment here is the steps.
1__Load some average scene switch to GPU
2__ CTRL+Spacebar in 3d viewport
3__ Use this setting (
A) :
- Block_size.jpg (8.08 KiB) Viewed 757 times
4__Go back to solid view and tip this setting (
B) :
- Pixel Size.jpg (8.41 KiB) Viewed 757 times
Repeat the operation as much as you want. Then wich setting is more responssive for you ?
Note that the part we want to focus on is first sample and speed while moving arround with the mouse.
I've my conclusion but wann't affect yours.
Re: GPU viewport performance
Posted: Thu Sep 03, 2020 1:16 pm
The settings should be correlated with the view port size. You can not have a single setting responsive for any view port size.
Posted: Thu Sep 03, 2020 1:40 pm
Dade wrote: ↑Thu Sep 03, 2020 1:16 pm
Yes it the case just made those test with same viewport size. Anyway one of the settings is much more responssive even considering primary sample.
Posted: Thu Sep 03, 2020 5:28 pm
Anyone else see a difference between the 2 settings in the first post ?
Posted: Thu Sep 03, 2020 6:22 pm
by JulianoLisboa
Wow, much faster option B.
Posted: Thu Sep 03, 2020 6:28 pm
I mean Dade even if option B is adding less pressure after first samples compared to A. The fluidity during first sample in option B is simply from another level and this almost no matter how high you set block size in option A.
So for me there is a weird thing we can improve here.
Posted: Thu Sep 03, 2020 6:31 pm
JulianoLisboa wrote: ↑Thu Sep 03, 2020 6:22 pm
Yes i felt exactly the same
Posted: Thu Sep 03, 2020 6:40 pm
Sharlybg wrote: ↑Thu Sep 03, 2020 6:28 pm
You are rendering 2x2 less pixels: it is 4 times faster.
Posted: Thu Sep 03, 2020 9:08 pm
Yes of course but it is not about render speed. But responsivness during navigation and user input.
If i follow you rendering at 2x2 should feel responssive like 16x1 ( block size = 16 ; pixel size = 1)
Try yourself just rotating in the scene don't let thing settle down just move as quick as you can.
Even 32x1 ( block size = 32 ; pixel size = 1) can't match 2x2 setting.
No matter the block size as soon as pixel size is set to 1 viewport navigation is laggy. I insiste on navigation responssivness.
Is possible to do inside luxcore code 2x2 during input and navigation and switch back to 8x1 automatically right after ?
Posted: Thu Sep 03, 2020 11:35 pm
Sharlybg wrote: ↑Thu Sep 03, 2020 9:08 pm
It is but it is a parameter BlendLuxCore doesn't expose (the number of samples it will take the transition from block to pixel rendering).
