Hm, 760 is shown, HD 4400 only in Luxmark not in the addon. If Luxmark render on the HD 4400 Luxcore should work too, doesn't it?
Thanks for watching, mib
LuxCore didt see OpenCL devices on Linux
Re: LuxCore didt see OpenCL devices on Linux
Yes, you should have command named "clinfo", can you post the output here ?mib2berlin wrote: ↑Wed Apr 18, 2018 10:52 am Hm, 760 is shown, HD 4400 only in Luxmark not in the addon. If Luxmark render on the HD 4400 Luxcore should work too, doesn't it?
I don´t have clinfo but another tool check_opencl, output is:
If I try to compile clinfo it errors out CL.h is missing and I think this is a problem.
I have installed:
intel-opencl-r5.0-63503.x86_64.rpm
intel-opencl-devel-r5.0-63503.x86_64.rpm
intel-opencl-r5.0-cpu-63503.x86_64.rpm
It seams it is only CPU installed, where I get GPU driver?
Platform : Intel(R) OpenCL
Platform extensions : cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64
Platform profile : FULL_PROFILE
Platform vendor : Intel(R) Corporation
Platform version : OpenCL 1.2 LINUX
Device number : 0
Device name : Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Device extensions : cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64
Device Opencl Version : OpenCL C 1.2
Device max comp unit : 4
Test of directory creation :
Creation of /tmp/test_check_opencl directory is OK
It will be removed
/tmp/test_check_opencl directory is removed
Test of directory creation with opencl name :
Creation of "/tmp"/test_check_openc_cl/Intel(R) Corporation
Creation of "/tmp/test_check_opencl/Intel(R) Corporation" : OK
Creation of "/tmp/test_check_opencl/Intel(R) Corporation/Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz" : OK
Creation of "/tmp/test_check_opencl/Intel(R) Corporation/Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz/4" : OK
Ok, this make sense, I think BlendLuxCore shows only GPUs device (because they are now the only type of useful devices thanks to hybrid rendering) while LuxMark show every type of device.mib2berlin wrote: ↑Wed Apr 18, 2018 1:53 pm It seams it is only CPU installed, where I get GPU driver?
I'm not sure but some time ago, Intel OpenCL for HD4000 was available only under Windows
IIRC the test I made was on WIndows, haha.
It is not important to me, thank you for the help.
May in the future they support iGPU too.
Cheers, mib
Cheers, mib
Yes, CPU devices are not shown in the addon.
https://github.com/LuxCoreRender/BlendL ... ig.py#L178
Guys I finally found solution for fedora systems and Nvidia cards! For OpenCL luxcore just needed to remove some files from "etc/OpenCL/vendors" directory. Only nvidia.icd must stay here and luxcore OpenCl start working!
Удачи всем!
Удачи всем!
Great to hear that, thanks for posting the solution
Thanks for awesome render engine! =)
