Stability and performance
jensverwiebe
Supporting Users
Re: Stability and performance
Post by jensverwiebe »
Egert_Kanep wrote: Fri Mar 30, 2018 12:52 pm Thanks for quick responses. I realized I had older version of Blender installed so I updated is to latest version. The first error is gone, but new error popped up.
Replace the libs with the ones i posted anyway.
arena10 missing leads to linking to outdarted tbbmallic in sys.
My embree avoids this.
You may have an older versions of Intel TBB library installed. Try to run the following command line:
ldd /home/egert/.config/blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so
This is the output in my case:
david@i7-3930k:~/projects/luxcorerender/LuxCore$ ldd /home/david/.config/blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so
	linux-vdso.so.1 =>  (0x00007ffdb9fe3000)
	libembree.so.2 => /home/david/projects/luxcorerender/embree-2.17.1.x86_64.linux/lib/libembree.so.2 (0x00007f9eccfcc000)
	libboost_thread.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_thread.so.1.56.0 (0x00007f9eccdac000)
	libboost_filesystem.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_filesystem.so.1.56.0 (0x00007f9eccb95000)
	libboost_serialization.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_serialization.so.1.56.0 (0x00007f9ecc936000)
	libboost_iostreams.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_iostreams.so.1.56.0 (0x00007f9ecc71e000)
	libboost_regex.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_regex.so.1.56.0 (0x00007f9ecc40f000)
	libboost_system.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_system.so.1.56.0 (0x00007f9ecc20b000)
	libboost_python.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_python.so.1.56.0 (0x00007f9ecbfbe000)
	libboost_chrono.so.1.56.0 => /home/david/projects/luxcorerender/boost_1_56_0-bin/lib/libboost_chrono.so.1.56.0 (0x00007f9ecbdb7000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9ecbb99000)
	libHalf.so.6 => /usr/lib/x86_64-linux-gnu/libHalf.so.6 (0x00007f9ecb956000)
	libOpenImageIO.so.1.4 => /home/david/projects/luxcorerender/oiio/dist/linux64/lib/libOpenImageIO.so.1.4 (0x00007f9ecb0a8000)
	libGL.so.1 => /usr/lib/fglrx/libGL.so.1 (0x00007f9ecaeb7000)
	libOpenCL.so.1 => /usr/local/cuda-8.0/lib64/libOpenCL.so.1 (0x00007f9ecacb1000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9eca9ad000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9eca6a7000)
	libgomp.so.1 => /usr/lib/x86_64-linux-gnu/libgomp.so.1 (0x00007f9eca498000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9eca282000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9ec9eb9000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9ec9cb5000)
	libtbb.so.2 => /home/david/projects/luxcorerender/embree-2.17.1.x86_64.linux/lib/libtbb.so.2 (0x00007f9ec9a5e000)
	libtbbmalloc.so.2 => /home/david/projects/luxcorerender/embree-2.17.1.x86_64.linux/lib/libtbbmalloc.so.2 (0x00007f9ec980a000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f9ed04dd000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9ec9602000)
	libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9ec93e9000)
	libbz2.so.1.0 => /lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007f9ec91d9000)
	libicuuc.so.52 => /usr/lib/x86_64-linux-gnu/libicuuc.so.52 (0x00007f9ec8e60000)
	libicui18n.so.52 => /usr/lib/x86_64-linux-gnu/libicui18n.so.52 (0x00007f9ec8a59000)
	libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f9ec87b6000)
	libIex.so.6 => /usr/lib/x86_64-linux-gnu/libIex.so.6 (0x00007f9ec8598000)
	libpng12.so.0 => /lib/x86_64-linux-gnu/libpng12.so.0 (0x00007f9ec8372000)
	libtiff.so.5 => /usr/lib/x86_64-linux-gnu/libtiff.so.5 (0x00007f9ec80ff000)
	libjpeg.so.8 => /usr/lib/x86_64-linux-gnu/libjpeg.so.8 (0x00007f9ec7eaa000)
	libIlmImf.so.6 => /usr/lib/x86_64-linux-gnu/libIlmImf.so.6 (0x00007f9ec7bfb000)
	libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f9ec79e9000)
	libatiuki.so.1 => /usr/lib/libatiuki.so.1 (0x00007f9ed05a5000)
	libicudata.so.52 => /usr/lib/x86_64-linux-gnu/libicudata.so.52 (0x00007f9ec617c000)
	liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f9ec5f5a000)
	libjbig.so.0 => /usr/lib/x86_64-linux-gnu/libjbig.so.0 (0x00007f9ec5d4c000)
	libIlmThread.so.6 => /usr/lib/x86_64-linux-gnu/libIlmThread.so.6 (0x00007f9ec5b46000)
	libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f9ec5811000)
	libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f9ec55f2000)
	libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f9ec53ee000)
	libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f9ec51e8000)
Post your output here. We have to check the following lines:
because I'm pretty sure you are missing the /home/david/projects/luxcorerender/embree-2.17.1.x86_64.linux/lib/libtbb*.so.2 files or they are resolved with some older version installed in your system.
jensverwiebe
Supporting Users
Pyluxcore.so is NOT the problem, see again: viewtopic.php?f=4&t=193&sid=005e28407a6 ... 8ec7#p2510
Use my libs, specifically the tuned libembree, period.
jensverwiebe wrote: Fri Mar 30, 2018 1:40 pm Pyluxcore.so is NOT the problem, see again: viewtopic.php?f=4&t=193&sid=005e28407a6 ... 8ec7#p2510
You can use all the "period" you like and be still wrong.
Egert_Kanep
Post by Egert_Kanep »
I tried this code you asked and got this.
	linux-vdso.so.1 =>  (0x00007ffc95e82000)
	libembree.so.2 => /home/egert/.config/blender/2.79/scripts/addons/BlendLuxCore/bin/libembree.so.2 (0x00007f28d2f8d000)
	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f28d2d70000)
	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f28d2a67000)
	libgomp.so.1 => /usr/lib/x86_64-linux-gnu/libgomp.so.1 (0x00007f28d2845000)
	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f28d262f000)
	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f28d2265000)
	/lib64/ld-linux-x86-64.so.2 (0x00007f28d6c10000)
	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f28d2061000)
	libtbb.so.2 => /home/egert/.config/blender/2.79/scripts/addons/BlendLuxCore/bin/libtbb.so.2 (0x00007f28d1e0a000)
	libtbbmalloc.so.2 => /home/egert/.config/blender/2.79/scripts/addons/BlendLuxCore/bin/libtbbmalloc.so.2 (0x00007f28d1bb6000)
	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f28d1834000)
	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f28d162c000)
Egert_Kanep
I found my problem, why LuxCore did not work. I downloaded blender via command line and installed it, but then those errors occurred. Now I downloaded it straight from blender.org and everything works. Except my gpu, that is something that I still need to fix, then I can start experimenting with Linux version
In that case your Blender version was probably outdated.
BlendLuxCore only works with 2.79a and above, there are some bugs and missing features in lower Blender versions.
