Stability and performance
- Egert_Kanep
Hello!
I was wondering if LuxCoreRender would give even better results when using Linux versions.
I know some software performs better and is more stable on Linux. Has anyone compared it? Or what are your thoughts on this matter?
Re: Stability and performance
Linux may perform (a lot) better when using hybrid rendering (CPU+GPU rendering, enabled by default). The Windows scheduler is really bad, I can barely move my mouse when compiling Lux on Windows, no problem on Linux.Egert_Kanep wrote: ↑Tue Mar 27, 2018 1:18 pm I was wondering if LuxCoreRender would give even better results when using Linux versions.
The same kind of problem may lead to a difficulty in feeding fast enough the GPUs when the CPU is busy doing rendering too. It doesn't happen on Linux but we have received some report about this problem on Windows. It is something I have still to check on Windows. It may be worth leaving 1 or 2 cores free on Windows to have the space to "feed" the GPUs fast enough.
For the rest, there may be some difference in code optimization done be GCC vs VisualStudio C++ but it is usually a minor difference.
- Egert_Kanep
Okay, I think I'll give linux version a try.
- Egert_Kanep
I managed to get Linux working, but after installing LuxCoreRender addon I get this error message. I guess it is related to my files location, but I can't really understand the problem.
It means that it is missing a library file (like a DLL on windows) and can't load it.
Can you test it with this zip file? https://www.dropbox.com/s/5d56jggyb0brl ... v.zip?dl=1
Remove the failed installation first.
- Supporting Users
I'd say this is expected cause libembree is not designed correct for stationary use.Egert_Kanep wrote: ↑Fri Mar 30, 2018 8:16 am I managed to get Linux working, but after installing LuxCoreRender addon I get this error message. I guess it is related to my files location, but I can't really understand the problem.
Such will also happen if you use a dynamically linked blender ( selfcompiled )
There is a thread where i explained the issue.
If you want you can get a fixed libembree.
To make things short:
- get the libs replacement i pm'ed you.
- unpack and place in : /home/<your_userhome>/.config/blender/2.79/scripts/addons/BlendLuxCore/bin
If the issue persists, you have a dynamic blender and need the other trick described in the SteffenD thread or
get an official 2.79a/b.
- Egert_Kanep
Thanks for quick responses. I realized I had older version of Blender installed so I updated is to latest version. The first error is gone, but new error popped up.
Is that with the zip file I posted above?
- Egert_Kanep
I doubt it. The "install from file" button is enough.Egert_Kanep wrote: ↑Fri Mar 30, 2018 12:59 pm it may be, that I have installed something incorrectly.
I'm a bit at a loss what it could be. Maybe a version conflict with a pre-installed embree version?
